Old 04-01-2017, 05:07 PM   #1
Water...
Put water in holding tank, a couple days ago and we just set up for the first time, with a brand new 3950TZ. No water at campground yet, so essentially we're dry camping. I set the levers in the correct position, to get water via pump, and water comes shooting out the hose inlet, where city water would go. HEEEELLPPP! Brand new and nothing but problems.
Dylanfreak is offline   Reply With Quote
Old 04-01-2017, 05:23 PM   #2
fonzie's Avatar
Remove screen at city water inlet and reset check valve....
Water shooting out of city water inlet when pump runs
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-01-2017, 05:27 PM   #3
How do you reset it?
Old 04-01-2017, 05:29 PM   #4
SeaDog's Avatar
read the link forzei posted for you that tells you what to do. let the forum know if it works
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-01-2017, 05:44 PM   #5
jtstromsburg's Avatar
Remove the screen and washer and use your finger or small screwdriver to are fully tap that check valve and see if you can get it to pop back out in place. If it doesn't want to fix itself, you may have to remove it and replace that part. Not too bad of a job as long as you can get to the backside ok.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-01-2017, 05:51 PM   #6
If you cant get it to reset and stop leaking, you can temporarily screw a 1/4 turn hose shutoff (made to screw on the end of a garden hose) into the city water port. Simply screw on and close the valve via the little knob/lever.
It will keep the water from backflowing out the port when your pump is on.
Days Camped: '17=30 '18=51 '19=58 '20=21
water
