Old 02-06-2011, 01:07 AM   #1
Water Filter location on a 37RL
Does anyone know where the water filter is located on a 2007 37RL?
sddmr7 is offline   Reply With Quote
Old 02-06-2011, 07:47 AM   #2
cardinal4fun's Avatar
I do not have the same, however set-up may be same or close to it. In the outside storage compartment on the drivers side door there is a slider door that opens up the area for the water pump, inverter, and filter. My filter is on the back wall, very hard to get to.
Hope this helps
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 02-06-2011, 11:04 AM   #3
Traveler II's Avatar
We have a 30TS and our is located the same as above. I'm sure that it would be by the water pump.
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
Old 02-07-2011, 12:34 AM   #4
Smile Water filter found.
Your info was good and I found it. You need to be half Stretch Armstrong and half Gummbie to change the cartridge. Thanks for the help.
37rl, water filter, water flow
