Old 04-09-2017, 11:24 AM   #1
Water flow
Brand new 2017 cardinal, 3950tz. Staying at a major resort, put a gauge on the water, and it's at 100psi. Always use the regulator, which brings it all the way to 40. Question is, since the flow ain't all that great, especially in the shower, does anyone NOT use the regulator, and ate the new trailers more capable of handling the pressure? Also, am I correct in saying, that you can't just open the spicket a little, because the pressure will still be wherever the campground pressure is, in this case, 100.
Dylanfreak is offline   Reply With Quote
Old 04-09-2017, 11:38 AM   #2
Just as confused as you
Scrapper's Avatar
I personally would not go above 45 psi if you get an adjustable regulator. I don't know if the valve on the toilet could handle more than that.
Richard & Jill
Old 04-09-2017, 12:33 PM   #3
llr
If you opened the spigot a little you still have full pressure when you are not using water, and probably very low when you are using water
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
llr is offline   Reply With Quote
Old 04-11-2017, 04:42 PM   #4
jacknife's Avatar
My shower head did not flow well . l replaced it with one from CW and it worked much better. Sometimes the regulator's are more restrictive then rated. We had that problem . Got a new one and the pressure was much better.
jacknife is offline   Reply With Quote
Old 04-11-2017, 04:53 PM   #5
Try this pressure regulator 50-55psi
Hi Flow Water Regulator - Lead Free - Valterra A01-1122VP - Faucets & Inlets - Camping World
13larry is offline   Reply With Quote
Old 04-11-2017, 05:04 PM   #6
dbledan's Avatar
I use this. https://www.amazon.com/gp/aw/d/B01MR...sure+regulator
I had a Y before it at one point but it restricted the flow too much. I removed the Y and shower problem solved. Look for the choke point. Sometimes it is the pressure regulator but if you get pressure at turn on and then it drops it is a flow problem.
dbledan is offline   Reply With Quote
water, water flow
