Old 06-27-2016, 02:21 PM   #1
Amerirver's Avatar
Water Heater Bypass - 2016 3825FL
Does anyone know if there is a bypass valve for the water heater?
Amerirver is offline   Reply With Quote
Old 06-27-2016, 03:22 PM   #2
I see a posting just below yours by: nedwards1959 who has the SAME UNIT......you should PM each other as you find your paths through these new rigs.
Good luck
SilverbackMel is offline   Reply With Quote
Old 06-27-2016, 03:36 PM   #3
Bypass valves are usually right behind the water heater. Take a look.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 06-27-2016, 03:49 PM   #4
Moderators' Assistant
bikendan's Avatar
As far as i know, every RV with a water heater, has a bypass valve for winterization.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-27-2016, 03:52 PM   #5
Amerirver's Avatar
I'm not seeing any access to look behind the heater.
Old 06-27-2016, 04:04 PM   #6
wmtire's Avatar
That can be tricky, and you may have to remove a false panel, drawer, bed bottom, etc.
This may help:
NO (OR MINIMAL) HOT WATER (Please read first)
Also its possible you have an outside plumbing station with all the valves accessable.
2011 Flagstaff 831 RLBSS
I've invented a new word. "Plagiarism"
Old 06-27-2016, 04:26 PM   #7
Amerirver's Avatar
I would hope a serviceable part would be as easy as the picture that you've shown. I sure hope I don't have to disassemble the RV to get to the bypass valves. Thanks for sharing.
Old 06-27-2016, 04:44 PM   #8
We have to take out the bottom drawer in the dresser in the bedroom.
Lee and Anne
Old 07-05-2016, 07:46 PM   #9
My 3850RL has an access panel inside the basement. I havent actually removed it to look yet, but its right at the backside of the water heater on my unit.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 07-05-2016, 08:02 PM   #10
Ford Idaho's Avatar
I need to remove a panel under the fridge and then reach in about an arms length to work them.
Ford Idaho is online now   Reply With Quote
bypass, heater, water, water heater
