Old 07-24-2013, 04:33 PM   #1
Water not staying in commode
I think I need a new seal where the valve is, is this hard to do? Has anyone replaced the seal before by the flushing valve?
Ray
Maray7611 is offline   Reply With Quote
Old 07-24-2013, 04:38 PM   #2
TURBS's Avatar
Have you trird cleaning the seal top and bottom and checking for debris?
Turbs
Old 07-24-2013, 04:42 PM   #3
Turbs
Well I think what happened is just recently I had a problem with tank being clogged and could not drain it, had to run a snake through it and the rubbing of the snake may have worn it down
Old 07-29-2013, 03:16 PM   #4
I really like the Cardinal fifth wheels and I have one, but do they make one with two bedrooms?
Ray
Old 08-01-2013, 01:01 PM   #5
Dallas Texas
TexasBBQ's Avatar
Replacing the seal is not to hard. Not sure which brand you have but look on their website and youtube. There are a few videos on there, a couple show what not to do.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 08-01-2013, 01:09 PM   #6
Thank you
Old 08-20-2013, 09:41 PM   #7
CTDguy's Avatar
This may be too late, but I had the same problem in my 2005 Cardinal Platinum 35 RLT. It was just one of the mounting nuts being loose on one side of the commode. I tightened the loose nut and viola, no more leaking seal.
2005 Cardinal Platinum 35 CKT
1999 Dodge Ram 3500 CTD Dually Crewcab with Lots of Mods.
CTDguy is offline   Reply With Quote
Old 08-20-2013, 10:05 PM   #8
I just had the same issue it was the spring on the side of the commode, see if the water stays in if you lift up on the foot handle to seat the valve 100%
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 08-29-2013, 02:18 AM   #9
wayne nichols's Avatar
I had the same problem with a sealand toilet. With mine the ball wouldnt rotate far enough to seal just a couple degrees, I had to make an adjustment to the placement of the ball. from the side good luck.
wayne nichols is offline   Reply With Quote
water
