Old 12-09-2018, 10:57 AM   #1
What do you tow your Cardinal 5th wheel with?
Hi everyone, Just wondering what your towing your trailer with and how does it handle, I am going to get a new truck this week and I am on the fence as to a SRW or a Dually. I have a 2016 2500 HD Duramx with extra leaf springs and a set of Timbrens towing a 3350 RLX with dry pin weight of 2250 lbs and dry weight of 12500 LBS. Stepping up to a one ton GMC next.
Thx for your replys
RV Bill
RVBill is offline   Reply With Quote
Old 12-09-2018, 11:30 AM   #2
Iím towing my 3350RLX with a 2016 GMC dually. Itís overkill for this trailer. We had been planning on getting a 3850, but ultimately decided it was too long for where we are at this stage of life. Any of the 2019 SRW trucks can handle the pin weight of the 3350. If you think youíll go bigger down the road, then go dually so you donít upgrade both at the same time.
With that said, Iíve got no complaints about my dually. Itís super stable and tows the trailer very nicely and I donít ever worry about exceeding my payload. In Oregon, land of the Prius and compact parking spaces, I do find myself parking way out in the back of lots and sometimes crossing parking lines, but the walk is good for me.
jtaylor1920 is offline   Reply With Quote
Old 12-09-2018, 12:11 PM   #3
That is exactly what I want to hear !!
I would love to have a dually to tow this with but not for a everyday driver.
Thanks you
Old 12-09-2018, 12:38 PM   #4
I think it's probably close, but seems doable.
GVWR of that 5er is 16,200 (and change).
20% of that is ~4,000 lbs
My 2017 Ram 3500 has rear axle weight rating of 7,000
Rear Axle weight of my truck unloaded is ~2800 lbs.
At full GVWR of the 5er, I would be within 200 lbs of the rear axle weight rating, but exceeding the payload by about 600 lbs.
If you are one who is more focused on the Rear Axle weight (which I am), it would be close, but doeable.. just need to watch weights.
If you are a strict payload guy, if you get close to 16,000 loaded you will likely exceed payload.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is offline   Reply With Quote
Old 12-09-2018, 12:38 PM   #5
i tow my '18 3350rlx with a non dually, and it pulls fine
[and, i like the non dually for running around town]
now i must say, i'm still getting used to this whole package,
and a dually "might" be a little nicer/easier on the road,
but dually owners might want to chime in, with their opinions
marc
2018 forest river Cardinal 3350 rlx 5th wheel
2018 ford super duty 350, 2 door, SRW
FL-mph21 is offline   Reply With Quote
Old 12-09-2018, 12:53 PM   #6
Iím reaching out to a buddy that weighed his setup fully loaded to camp and will post his numbers. Heís towing with a 2019 SRW Ford F-350.
Old 12-09-2018, 01:20 PM   #7
bigdaddy1
bigdaddy1's Avatar
I tow my 3350RLX with my F-350 srw with no problem at all. Had a 3850 Cardinal that was heavier but pulled it west of Mississippi River with all ease. I did put air bags on truck but now run usually 40 to 45 lbs in them.
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
2019 3350RLX
bigdaddy1 is offline   Reply With Quote
Old 12-09-2018, 01:21 PM   #8
I'm in the Dually group. Prior to my MH I towed a 19,000 lb 5ver with a RAM dually, CC, LB. Never an issue with pulling, handling and comfort level. Solo parking takes more care. Always back in. However, if you will never go to a bigger 5ver then a 3500 SRW will suffice. But like most of us if you look at a larger unit you just might like the option to upgrade to the larger 5ver. It's impossible to resist looking at larger units at dealers, shows, etc. And NEVER let the DW look at a larger unit. Then you are doomed to make a trade.
2018 DX3 37TS Sunset
rskeans is offline   Reply With Quote
Old 12-09-2018, 02:15 PM   #9
Retired Member
rmwmiata's Avatar
Sierra 377 FLIK, Ram dually but I am retired and don't have to drive it daily.
Pam and Murry Wilbanks
2018 SIERRA 377 FLIK
2018 Ram Laramie 3500 DRW
rmwmiata is offline   Reply With Quote
Old 12-09-2018, 03:25 PM   #10
RVBill,
I'm also in the dually camp for fivers. I'm also retired so take this for what its worth. My fiver is only 12000 lbs and I pull with an older F350 long bed crew cab (overkill, maybe?). Its a mile long truck, but the stability, going down the highway is worth it to me. Heck, call me crazy but my fiver is in cold storage now and I'm still driving the dually around town, just for the fun of it. Yup, that's me, parked way down the end of the hardware store parking lot. Meanwhile my Tundra daily driver sits in the garage. Used it for 120 mile round trip commute when I worked. But I love it too. I guess sometimes you just need two trucks!!
herewego is offline   Reply With Quote
5th wheel, wheel
