Old 10-20-2016, 04:29 PM   #1
Pipcoo15's Avatar
Winterizing
New cardinal 3250rl . Looking to by pass water heater, went in storage area , took off panel, saw white and blue hoses runoff from water heater area, but no relay switch . Am I in the right area.
Pipcoo15 is offline   Reply With Quote
Old 10-20-2016, 05:20 PM   #2
SeaDog's Avatar
Most water heater bypass are done with manual valves. You close the inlet and outlet and open the bypass. If I'm reading your post correctly you are looking for an electrical relay?
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-20-2016, 06:26 PM   #3
Does your water panel look like this one in this thread?
http://www.forestriverforums.com/for...em-119957.html
If so, the water heater bypass is accomplished via this panel and the "winterize" settings. Download the instructions at the link provided as the winterization process while not hard, has some extra steps.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
winter
