Old 07-24-2012, 10:10 PM   #1
wrinkled ceiling at the seams
Has anyone every had the ceiling paper wrinkle out from under the trim.....It has happened at every joint....thank you in advance for any responses......Also how about problems with the the panel for all the levels........it has been replaced once......
dandlbro is offline   Reply With Quote
Old 08-01-2012, 06:17 PM   #2
Some have replaced the trim with a wider one. I believe that you can get them from Cardinal. Shipping is as much as the trim.
wvcampers is offline   Reply With Quote
Old 08-02-2012, 07:02 AM   #3
Dallas Texas
TexasBBQ's Avatar
I've got similar wrinkles. I had them in my second camper as well. They are not too bad so I've left them alone. Maybe one day I'll see if I can push them out or inject s little adhesive inside and flatten them out.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 08-02-2012, 07:57 AM   #4
That is probably a sign of too much moisture in the camper. Most people don't realise just how much moisture is produced by everyday living, let alone taking showers in such a confined space. Keep those campers aired out!
bakken is offline   Reply With Quote
