Old 05-23-2019, 12:40 PM   #1
2019 27 rks
Anyone familiar with this unit? I'm having a water system issue. Had it about a week and not ready to take back to the dealer?
Marty
Nomad marty is offline   Reply With Quote
Old 05-23-2019, 12:48 PM   #2
Iwannacamp's Avatar
I do not have your unit, but we can try to help.
What is your issue?
2017 Puma 297RLSS
Old 05-23-2019, 12:54 PM   #3
There is no manual on this but when fresh water tank is to be used, I turn on the pump but can't get any water inside. So I have to empty the tank and water pump has to be running to empty.
Marty
Old 05-23-2019, 01:28 PM   #4
Iwannacamp's Avatar
Do you know where the winterizing hose is? I bet the valve is set to winterize...IE pulling from the antifreeze inlet. Cheap easy check... Note: it is normally right at the water pump. Mine is under the sink and behind a panel. Deluxe units are outside in the "hose connection area"
2017 Puma 297RLSS
Old 05-23-2019, 01:31 PM   #5
I'll check it out and let you thanks
Marty
Old 05-23-2019, 01:32 PM   #6
On second thought on the service panel there is no winterizing valve
Marty
Old 05-23-2019, 01:35 PM   #7
If needing to drain the tank for some reason there is a drain on the fresh tank. Normally a white pipe with a screw off cap. Under your rig near fresh water fill port.
that winterizing valve is likely your problem.
gbaldwin is offline   Reply With Quote
Old 05-23-2019, 01:37 PM   #8
Marty
Is it not right at the pump/filter?
Old 05-23-2019, 01:48 PM   #9
Iwannacamp's Avatar
X2 on the strainer... even though not likely it can be stopped up... it will be at the pump.
2017 Puma 297RLSS
Old 05-23-2019, 01:50 PM   #10
You were right. That fixed the problem. Thanks
Marty
