Old 06-24-2018, 11:58 AM   #1
2nd A/C unit
I have a 2015 Shasta phoenix 30RL that is pre-wired for a second A/C unit.
What size unit would it take and is it ducted or non-ducted.
What components will I need to have a second one installed?
Thanks for your time.
Dave Hahn is offline   Reply With Quote
Old 06-24-2018, 12:10 PM   #2
Coolharts's Avatar
A 13,500 unit will work. You can take down the trim on the inside of your front roof vent and see if the ducts are there but capped off. You will need an A/C unit. If ducted you will need a control unit, bolts and thermostat kit. If not ducted you will need a controller and ceiling control unit.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
2018 25 2019 21
Coolharts is offline   Reply With Quote
Old 08-27-2018, 11:12 AM   #3
jtatum65's Avatar
Dave,
Did you get a 2nd A/C unit installed? If so how hard was it and do you have pictures of the install?
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2016 Dodge Ram 2500 Big Horn 6.4L Hemi 4x4
Nights Camped 2019 = 32
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 09-03-2018, 05:50 PM   #4
I did get a second A/C installed. Had my local RV place do it for me. All the wiring was there and the roof was already framed for the A/C. No dual thermostat just local control of unit. They put in a 13500btu and when all was said and done it cost right around $1000. Well worth it in my opinion. Now the bedroom is nice and cool.
Old 09-03-2018, 09:10 PM   #5
jtatum65's Avatar
Which AC did they install? Mach? Dometic? And your unit didnt have the dual zone controller on the wall? I was told by Shasta, if the camper has the dual wall unit, then the wiring is there to tie in the 2nd AC to that t-stat.
Jim & Evelyn Tatum
Old 09-04-2018, 03:47 PM   #6
Went with the Mach and no dual controller on the wall.
