Old 09-19-2014, 09:33 AM   #1
wicked1's Avatar
Batteries
I have one now on my 27? Thinking of adding a second and a marine 2 battery switch? Has anyone does this and is it a good idea?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 09-19-2014, 09:44 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I don't see why not. The caveat would be they won't be charged simultaneously, I would install 2 similar (better identical) 12 Volt batteries in parallel instead of switching.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-19-2014, 10:21 AM   #3
mud yapster's Avatar
X2
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-19-2014, 10:29 AM   #4
wicked1's Avatar
Ok easy to do but is it better for 2 marine 12 volts? I hear some putting 4 6 volts in their RV's. I switched from boating where I always had 4 Heavy Duty Marine 12V batteries so familiar with the design just not sure which works best
Old 09-19-2014, 10:52 AM   #5
If you want to go this route
2 6 Volt 230 Amp True Deep Cycle batteries would be even better, or 4 or 6 but watch out for the weight, they are 75# a piece.
Golf cart batteries would be a good option, or AGM's they're expensive but maintenance free and will not cause corrosion due to off gassing in the battery bay and will last you a long time if you keep them charged properly.
Old 09-19-2014, 11:09 AM   #6
Kaadk's Avatar
You can do either 12's or 6's, depending on your choice. The general consensus seems to be that the 6's provide more total AmpHours than 12's but that's going to come down to the specific batteries you buy. The trade off is the 6's take more weight/space (because you need 2) and usually cost more.
If you're looking to add to the existing battery, I'd stick with what you're proposing. Just add another 12 and control it with a switch. You don't want to just wire a new one in parallel without the switch unless your replacing the existing battery since you want the batteries to be the same. Mixing and matching could lead to premature failure of the batteries otherwise.
The only recommendation I'd make is to look for a true deep cycle over a marine battery. (Unless of course you happen to have them laying around already.) A marine battery usually doesn't provide as many AH as an equivalently sized deep cycle because the marine is setup to provide some CCA, where as the deep cycle is not.
battery
