Old 07-25-2019, 05:25 PM   #1
black & grey holding tank valves
hello . We have a 2016 Shasta 25rs. we went to dump the black & gray tanks and could not determine which valve dumped the 2 tanks. Guess the valve closest to the tires snd the valve closest to the back would be a good way for anyone to tell us. Both valves are black. thanks
nephi007 is offline   Reply With Quote
Old 07-25-2019, 05:28 PM   #2
the handles may be black but they should be two separate tanks. black tank is going to have a larger diameter pipe.
Kimber45 is offline   Reply With Quote
Old 07-25-2019, 05:39 PM   #3
Fulltime family RVer
Based on the layout:
https://shastarving.com/travel-trail...asta/25RS/4271
And the fact that you have 36g black and 72g gray tells me that you have 2 gray tanks and 1 black tank.
Based on layout, I'm willing to guess that you have 2 sewer connections on the outside of the camper.
In my opinion, if there's dirty water in the tanks- put on a clear elbow, hook up sewer, and start pulling handles. Gray vs. black becomes apparently real quick.
ependydad is online now   Reply With Quote
Old 07-25-2019, 07:19 PM   #4
ageed! a clear plastic elbow will tell you. and it will tell you other things once you know which is which.
if you can see the actual valves the gray tanks drain is 1 1/2" and the black tank drain is 3".
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-25-2019, 08:00 PM   #5
thanks for the replies everybody. Yes the valves are not color coded (black valve for black tank & gray valve for gray water is not the case here) so i pulled the valve in the left ( closest to the tires) of the discharge tube and it was the gray water that discharged. There is another valve for the galley gray water to the right and under the water heater with its own discharge tube. I called Shasta.com and the lady confirmed that left valve was for gray water and right was for black water. thanks again
black, tank, valve
