Old 11-21-2018, 12:27 PM   #1
Fifth wheel sway problems
I have a 2019 Shasta Pheonix 370fe. I tow it with a 2017 ram 2500 stock short bed with a Reece 25K Q. The receiver is bolted on the lowest hole (after our fittest trip) . We encountered sway at 65. Anyone have similar problems.
TheRoberts4 is offline   Reply With Quote
Old 11-21-2018, 12:52 PM   #2
Denver To Yuma In 90 Days
The only thing I can think of is that you don't have enough pin weight...
Or your 5'ver is too big and heavy for your truck.
After looking it up online...I believe it is probably too big and heavy for your truck.
Here are the specs I found for your 5'ver...
2019 Shasta Phoenix 370FE
Year 2019
Brand Shasta
Type Fifth Wheel
UVW 11,869 lbs
Dry Hitch 2,324 lbs
CCC 2,631 lbs
GVWR 14,500 lbs
Length (ft,in) 41' 9"
Width (ft,in) 8'
Height (ft,in) 12' 9"
Fresh Tank 48 gal
Gray Tank 90 gal
Black Tank 45 gal
Sleeps 6
Slides 5
JohnD10 is offline   Reply With Quote
Old 11-21-2018, 01:06 PM   #3
Prime Member
Year 2019
Brand Shasta
Type Fifth Wheel
UVW 11,869 lbs
Dry Hitch 2,324 lbs
CCC 2,631 lbs
GVWR 14,500 lbs
Width (ft,in) 8'
Fresh Tank 48 gal
Gray Tank 90 gal
Black Tank 45 gal
Sleeps 6
Slides 5
Agreed. This definitely looks like a camper where a 3500 is needed.
Temporarily Camper-Less
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 11-21-2018, 01:53 PM   #4
FordHauler's Avatar
Too much tail, not enough dog!
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
FordHauler is offline   Reply With Quote
Old 11-21-2018, 02:01 PM   #5
NMWildcat's Avatar
My experience with any sway in a fiver is usually due to too much weight in the rear (not enough pin weight) and/or being out of level more than a few inches.
Tires and inflation could be part of the problem, but weight loads seem more prevalent.
As far as the weight police piling on, your truck is definitely near the limits with this trailer. But that being said, I've seen lots of folks towing the same or more with a 3/4 ton and no sway.
Our fiver is right at 12k loaded and the only time I get any sway is when the 50 gallon fresh tank is full and we have a gusty crosswind. Some idiot engineer thought it was a good idea to put it in the very back of the fiver
Scott and Liz - Southern NM
Old 11-21-2018, 02:03 PM   #6
I'm Lost
wabakami's Avatar
Re-balance your fiver.
Upgrade or modify your truck.
Or, drive at 60!
Geoff
Geoff, Francesca and Lucy the Golden holy terror (I mean retriever, BD Nov. 2018)
2013 F150 Screw, 6.2L gasser, HDPP, LT tyres, Firestone Air Bags, 250L aux tank.
2013 Rockwood Signature 8310SS
wabakami is offline   Reply With Quote
Old 11-21-2018, 02:03 PM   #7
You're funny...
Old 11-21-2018, 02:07 PM   #8
NMWildcat's Avatar
You're funny...
I try
Old 11-21-2018, 03:06 PM   #9
MillMitch's Avatar
This caught my eye because I've been looking at Ram 2500's the past couple weeks. I'm sure there are HD versions with bigger numbers, but most of the 2018's on the lot near me w/ the 6.4L list GVW at 9000, GCVW at 18,300, max trailer weight at 11,200, max tongue at 1120, and max 5er at 11,020.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
MillMitch is offline   Reply With Quote
Old 11-21-2018, 04:58 PM   #10
Problem fixed. I'm almost 4000 under tow weight, the problem was 2 things. Receiver was set to high and the pin box to low. I lowered the receiver to lowest bolt hole and raised the pin box one hole. I have enough clearance for the pinch point (6 1/2 inches). I made the adjustments today and took it for ride....0 problems. No sway. After doing some research on other forms, I found that the Ram 2500 and 3500 stock height is really high and causes problems with fifth wheels. The stock height for the bed rail at the receiver is 59 and 1/2 in unloaded.
Old 11-21-2018, 05:49 PM   #11
NMWildcat's Avatar
Fantastic! Congrats on the easy fix.
Old 11-21-2018, 06:00 PM   #12
Glad you got it working to your satisfaction.
You mentioned in your original post that you had lowered the hitch after your first trip and then mention that again as part of what corrected the sway.
Had you not driven the rig after lowering the hitch?
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 11-21-2018, 06:23 PM   #13
Originally Posted by TheRoberts4 View Post
I'm almost 4000 under tow weight...
What does that mean...
And how did you figure that number?
Old 11-21-2018, 07:17 PM   #14
Prime Member
Sounds like he's looking at the towing capacity instead of payload capacity.
Old 11-21-2018, 08:05 PM   #15
Yup!
He is overweight for that truck...
I should add that before anyone jumps on me for towing a 5'ver with a short box 2500HD (3/4 ton truck)...
My 5'ver weighs in at roughly 9500 pounds loaded and is 33-feet long...well within the tow rating of my truck!
Old 11-22-2018, 06:46 AM   #16
Prime Member
Yup!
Your 5er would be too much for my 3/4 ton diesel. My payload capacity is 2400lbs and I regularly travel with 4 full size adults
Old 11-22-2018, 11:02 AM   #17
And therein lies one of the disadvantages of a diesel. My fifth wheel is similar to John's. The payload on my F-250 SD 6.2L gas gives me plenty.
ID:	191994Click image for larger version
Old 11-22-2018, 11:31 AM   #18
NMWildcat's Avatar
OP's problem was resolved by adjusting king pin box and hitch heights. Had nothing to do with weight capacities or the ridiculous manufacturer's CC suggestion. Weight police should start another thread
Old 11-22-2018, 12:14 PM   #19
saus's Avatar
Amazing even on thanksgiving you’re reply has to try and provoke someone. Once again the last line is not needed. Back on post 5 you suggested that the OP was close to his weight limit. Are you now the weight police that you mention here in this reply?
2016 Forest River Wildcat 314BHX
2019 Ford F-450 Limited DRW 6.7 Diesel
saus is offline   Reply With Quote
Old 11-22-2018, 12:36 PM   #20
NMWildcat's Avatar
Happy Thanksgiving to you also Saus! Always enjoyable!!!
fifth wheel, sway, wheel
