Old 06-01-2012, 11:21 AM   #11
prof_fate's Avatar
Originally Posted by boubou View Post
We had a small leak from the hot water heater plug. We asked at the office for a ratchet (forgot that) and they sent us a truck an a man with a tool box. He had it fixed in a jiffy
last year our TT was new and came winterized so I had to put the anode/plug in...I played with it for over 1/2 hour.
I also learned that you MUST have a grounded cord if you plug in TT..or when you play with the water heater you'll get 'tingled' now and again. Of course it was the next day when I actually put that together...
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-02-2012, 12:29 PM   #12
Brigitte
boubou's Avatar
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 06-03-2012, 07:27 PM   #13
If you have a problem with the door hitting the awning arm,we just took a noodle you would use in the pool and cut it to slip over the awning arm so the door couldn't beat it up.
Optimus prime is offline   Reply With Quote
Old 06-03-2012, 10:04 PM   #14
Brigitte
boubou's Avatar
Thanks for the great tip
The door does not hit the awning arm but I am
Sure this noodle tip can come in handy at some point
Superglide 2700
Timbrens
