Old 05-07-2012, 03:56 PM   #1
Brigitte
boubou's Avatar
First issue, leak at water pump
While de-winterizing ( a first time experience for us), i noticed a leak at the water pump water intake. It seems to be coming from where the black screwy thingy goes into the pump. I just rotated it a quarter of a turn ( lifted the pipe) an it's barely dripping now. I'll wait after first trip to bring it in for warranty work in case other issues come up.
The other thing wrong is the storage door latch is short and does not stay put. Need longer one.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-07-2012, 04:41 PM   #2
Are you talking about the latch to hold it open? Had the same problem on the front storage door on our new 5ver. Solved the problem by adding 2 gas struts to all 3 storage doors and don't even need the latches now.
Old 05-07-2012, 04:44 PM   #3
Brigitte
boubou's Avatar
Nope, the twist metal clasp that keeps it closed. One with the lock is fine but the other one is short.
I should add that i keep a small towel under the leak
to catch the slow leak if it happens
Superglide 2700
Timbrens
Old 05-07-2012, 04:47 PM   #4
Picture would help.
Old 05-07-2012, 07:08 PM   #5
Brigitte
boubou's Avatar
This thingy is a bit short. It catches on the edge and the rubber but comes off and if the door isn't locked, it opens
Th is the mark left from the latch as it slips past the frame and lets the door open.
Will get a longer latch ... Hopefully they exist.
For leak picture, wouldnt e able to see it without adding water to fwy an using pump.
Superglide 2700
Timbrens
