My Swinging Door Fix
This was my fix for the swing door. I found the courage to drill the swing door and side of RV and installed a 4" T-holder, plastic cargo door holder. It keeps door from hitting the propane door latches and locks it into place. Another thought was using a bungie cord and 2 eye bolts. It could keep the door from swinging fully open when windy, then you could un-hook one end for full open, just haven't done it yet. Again requires drilling the door for installing the eye bolt.
As to low point drains, haven't found them either. The owners manual indicates using air to blow out the water lines then use water pump to suck antifreeze into system. We live in a warmer climate so antifreeze shouldn't be required, but draining the plumbing is. Doing more research!
Our rear window valance and curtains fell on our last trip. Only had 2 screws into the bottom overhead cabinet that is paper thin veneer. Fix was to install threaded sheetrock anchors where screws pulled out. Also installed a 3rd anchor in the middle.
cruisin
