Old 06-30-2013, 10:44 AM   #1
RollingDownTheHighway's Avatar
no hot water - again
I just de-winterized my camper and I have no hot water, the water heater has been running for about an hour and nothing but warm/cold water. I attached a pic of my water tank, are the valves positioned correctly?
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 06-30-2013, 11:07 AM   #2
Denver, CO
garbonz's Avatar
Valves are correct. Check fuses, breakers, igniters etc. Assume that you purged the water from the HW line before you kicked the heater on. Is it gas, 110v or both?
2017 Fuse 23T
Old 06-30-2013, 11:17 AM   #3
I learned that one cannot turn the switch off fast enough to prevent the electric element from burning up after realizing there's no water in the water heater when that "uh-oh" moment happens...
It should be easy enough to tell if the gas has kicked on...
Hudlow is offline   Reply With Quote
Old 06-30-2013, 01:33 PM   #4
bikendan's Avatar
also, check your outside shower.
Equalizer WDH
Old 07-01-2013, 05:22 AM   #5
@Bikendan, I don't have an outside shower on mine.
After letting the heater run for about an hour, I want back and tested it and I had hot water.
