Old 05-19-2012, 01:52 PM   #11
Brigitte
boubou's Avatar
Lolol
I'll give it a try
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-19-2012, 06:26 PM   #12
boubou, I had the same problem. It started with one outside speaker then both intermittently. Took the camper in for warranty work and the issue would not repeat for them. At exactly one year after purchase (warranty up) the radio would not respond to any "touch" screen prompts even after removing the radio and disconnecting power and resetting. Ultimately, I ended up going on ebay and purchasing a refurbished Jensen and installed. The install did require some mounting modifications but the unit is very reliable now and sounds 10X better!
JENSEN DVD/USB WALL MOUNT FOR CAMPER | eBay
Rich, Steph, Ava, & Micah
2010 Sierra 1500 SLE Z60
2011 Shasta Revere 30 CKBH
RichieD is offline   Reply With Quote
Old 05-19-2012, 08:04 PM   #13
Brigitte
boubou's Avatar
Thanks for the tip. I will bring it in for warranty repair, since it's not intermittent. It is just the one speaker and itjust doesnt have any sound coming from it. Once warranty is over andofI have more problem, I'lljust getthesameas your /
Superglide 2700
Timbrens
