Old 05-18-2012, 09:29 PM   #1
Brigitte
boubou's Avatar
One Outside speaker not working
One ( the oxne near the door) of two outside speaker not working.
I will bring TT in for warranty work sometime (this is not urgent, as long as it gets fixed) just wondering how ai could fix this myself if it's easy enough
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-18-2012, 09:40 PM   #2
sherdep's Avatar
could pull the radio out and check to see if it is a loose connection or verify it is the speaker or radio by swapping the speaker connections from one output to the other
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-19-2012, 01:01 AM   #3
Yep, ours did not work Either. Pulled stereo, and neither one of them were hooked up. Also we installed a cd and the unit "Ate" it. (So to speak). Noticed a sticker about removing screw before installing. Pulled out screw and all is well in the world
Roy
Tow rig= 2009 dodge ram 1500 5.7 not built for towing ,, but a show winner.
2012 Catalina 27FBCK (Our first trailer!!!!)
ke5wdq is offline   Reply With Quote
Old 05-19-2012, 03:23 AM   #4
Mountainmanbob's Avatar
probably a bad connection
either behind speaker
or behind your stereo unit
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 05-19-2012, 04:08 AM   #5
Malco's Avatar
Did it ever work?Ours was having an issue with the same speaker,except sometimes it would work and sometimes not.Having past history of breaking electronics when I try to fix them,I opened the upper cupboard door that was in front of where the speaker is located in relation to the inside,and hit the wall with the palm of my hand and it has been working fine ever since.My wife says it is the only thing I have ever been able to fix like that in my life and I did it without even taking it apart.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 05-19-2012, 04:39 AM   #6
DAISY BOYKIN's Avatar
MALCO is a----------
You are a electronic genius, keep up the good work!
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 05-19-2012, 06:23 AM   #7
sherdep's Avatar
boubou - what radio do you have?
Malco - you just masked the problem by beating it into submission
Old 05-19-2012, 07:44 AM   #8
Brigitte
boubou's Avatar
Touch Audio
I found the manual online including a diagram of the speaker wiring
http://manuals.heartlandowners.org/E...2010-09-08.pdf
How do I pull the unit out?
Also, I cannot see the back of the speaker in the cupboard, I'll start with the touch audio unit and see if a wire is loose. If not, then I'll get it looked when I go in for warranty work (small leak in water pump at the connection between water pump and hose, let them fix it )
Superglide 2700
Timbrens
Old 05-19-2012, 09:35 AM   #9
Brigitte
boubou's Avatar
I checked all speaker wires as per diagram, they are all connected firmly and the right colours at the right terminal.
Next check, speaker itself but when Imlooked at the screws easy access but it's caulked. i don't want to have to re-caulked. I know, I am intimidated my the caulking gun lol
i think I'll let the RV shop fix it under warranty.
Superglide 2700
Timbrens
Old 05-19-2012, 01:49 PM   #10
Malco's Avatar
Originally Posted by boubou View Post
Touch Audio
Oh, I couldn't see the back of the speaker either,I just hit the wall where I thought the speaker should be and presto,it was fixed.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
Old 05-19-2012, 01:52 PM   #11
Brigitte
boubou's Avatar
Lolol
I'll give it a try
Superglide 2700
Timbrens
Old 05-19-2012, 06:26 PM   #12
boubou, I had the same problem. It started with one outside speaker then both intermittently. Took the camper in for warranty work and the issue would not repeat for them. At exactly one year after purchase (warranty up) the radio would not respond to any "touch" screen prompts even after removing the radio and disconnecting power and resetting. Ultimately, I ended up going on ebay and purchasing a refurbished Jensen and installed. The install did require some mounting modifications but the unit is very reliable now and sounds 10X better!
JENSEN DVD/USB WALL MOUNT FOR CAMPER | eBay
Rich, Steph, Ava, & Micah
2010 Sierra 1500 SLE Z60
2011 Shasta Revere 30 CKBH
RichieD is offline   Reply With Quote
Old 05-19-2012, 08:04 PM   #13
Brigitte
boubou's Avatar
Thanks for the tip. I will bring it in for warranty repair, since it's not intermittent. It is just the one speaker and itjust doesnt have any sound coming from it. Once warranty is over andofI have more problem, I'lljust getthesameas your /
Superglide 2700
Timbrens
