Old 04-14-2019, 07:20 PM   #1
D Sgt's Avatar
Protecting my cargo door
I have a new 298RLS and my drivers side cargo door swings all the way forward when opening, striking the two latches for my propane tank bay. Not going to be long before the cargo door gets dented/damaged. Thought about using a foam noodle like I did not get slide out corners. Ideas for protecting the door? Anybody already experienced this? Thanks!
Phoenix 298RLS
2500 Ram Crew 4X4
DW & 3 pups
Ret LE 07/19
D Sgt is offline   Reply With Quote
Old 04-14-2019, 07:30 PM   #2
Here's what I did... Double duty. Keeps the door from hitting and holds the door open in the wind. Click image for larger version
ID:	201739Click image for larger version
beerbuggy is offline   Reply With Quote
Old 04-15-2019, 01:33 PM   #3
jtatum65's Avatar
I opted for the Hatchlift kit. Its a bit more expensive, but doesnt allow the door to swing all the way open. I am waiting for warmer weather to install mine, we did have a blizzard here in central IL yesterday....
https://www.hatchlift.com/hatchlift-kit
Jim & Evelyn Tatum
2018 Shasta Phoenix 336RL FW
2019 Dodge Ram 2500 Big Horn 6.4L 8spd 4x4
Nights Camped 2019 = 40
Nights Camped 2018 = 28
Nights Camped 2017 = 27
jtatum65 is offline   Reply With Quote
Old 04-15-2019, 01:49 PM   #4
I did what Beerbuggy did but instead of mounting the one piece with the rod on the camper wall I mounted it on the propane door, you can get the ones with the bumper on it as well. If you go this route make sure you get some good sealer to seal around the mounts.
wildcatter is offline   Reply With Quote
Old 04-15-2019, 02:59 PM   #5
D Sgt's Avatar
Thanks everybody! Good ideas all!
cargo, door
