Old 09-26-2017, 04:34 PM   #1
Shasta Revere 27bhss Water pump location.
I believe I've located the water pump under the kitchen sink?? How do I turn on pump with tube in jug of antifreeze? I've tried this, but NO anti-freeze is silhoned out of the jug of antifreeze.
2013 model .
Thanks,
Roy Riegel
Roy Riegel is offline   Reply With Quote
Old 09-28-2017, 08:41 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. Not knowing your rig I'll give you the basics. First bypass your water heater and pull the drain plug. Next find the antifreeze inlet port, open that valve, close the suction valve to the potable water tank. Put the hose (attach if necessary) from the antifreeze inlet port into the jug of antifreeze and turn on your pump. now open each faucet one at a time until you have pink antifreeze at that location and then close. how this helps.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
27bhss, cat, location, pump, shasta, water, water pump
