Old 03-31-2015, 08:21 AM   #1
wicked1's Avatar
Tire Pressure Question
I have the stock tires that came with my Shasta 27 RLSS they say max psi is 60 and I am running 50psi in each tire, first trip out this season locally and they seemed fine should I drop or raise the psi they are ST225/75/15
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 03-31-2015, 08:25 AM   #2
What does it say on the side of your trailer, should be a sticker with tire size and pressure. You normally want to run St tires at there Max Pressure.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-31-2015, 08:33 AM   #3
wicked1's Avatar
Stickers lettering is very hard to read faded but so I should run all 4 at 60? That would be ok to do?
Old 03-31-2015, 12:30 PM   #4
If it was me I would run them at 60.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 03-31-2015, 12:33 PM   #5
Read the sidewall on the tire, if it is an LR D, 65# is max, so run 65#.
Old 03-31-2015, 12:50 PM   #6
If you are running low pressure it will decrease your mileage. So run the max (10 psi cost me about 2mpg)
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 03-31-2015, 02:39 PM   #7
60 psi AT pressure is a strange value for American system .
C-load is always 50 psi and D-load always 65 psi.
European system has more exeptions .
So look again for C or D load or on one of the other tires for the right AT-pressure.
Most tire-makers even allow 10 psi above AT-pressure.
And ST tires are calculated in their maximum load for more deflection allowed at the lower maximum speed of 65 m/h.
but its better to give the tire a deflection that would be needed for 99m /h so the tires wont get that hot.
This gives more reserve and still no bumping.
Why use yust enaug pressure for the load , if you can have a confortable reserve.
And because most trailers are fitted with tires that can yust carry the gross axle weight rating together , the needed pressure comes mostly to the AT-presssure give on tie or belonging to the Loadkind.
10 psi higher would even be saver.
jadatis is offline   Reply With Quote
pressure, tire
