Old 04-25-2015, 07:19 AM   #1
roadmaven's Avatar
TV Addition
Having had our Oasis for just over two weeks now, we're starting to add a few touches to make it cozy. Last night we added a 28" Vizio LED TV that we picked up at Walmart for $198. It fits perfectly in the case, as I think a 32" would've been iffy. We did buy a mounting bracket, but chose not to use it, as the mounting bolts were pretty long and would've likely popped through the back wall where the bunks are. We just attached the TV to the stand it came with and set it in the cabinet. We'll just slide it back in its box when we travel, which will take a minute to set up or take down.
Pat B.
Speedway, IN
2016 Shasta Oasis 18BH
roadmaven is offline   Reply With Quote
Old 04-25-2015, 07:26 AM   #2
You can also bolt the base to the bottom of the shelf it sits on.
Old 05-10-2015, 12:43 PM   #3
What was the depth of your cabinet? Mine is 6 3/4". I'm having trouble finding a TV that will fit with the stand. I'd rather not mount it.
kscamping is offline   Reply With Quote
Old 05-11-2015, 05:10 PM   #4
roadmaven's Avatar
The cabinet on our 25BH is 6 3/4" as well. Here's the TV we went with: http://mobile.walmart.com/ip/VIZIO-E28H-C1-28-Class-720p-60Hz-Full-Array-LED-Smart-TV/43310239?type=search
We kept the box and will store it in the box under the sofa while traveling. But it fits great! We did our own walk thru video of our Oasis a couple weeks ago and I highlight the TV a little bit: http://youtu.be/E1LYmMW6nvg
Old 05-11-2015, 05:43 PM   #5
Thank you!!! Walmart here I come!
