Old 07-19-2018, 10:08 PM   #1
Tv issue
We bought a used 2015 Shasta revere 32ds and Iím have a problem getting channels on antenna tv. I get 5 channels 1 that you can actually watch. Can someone please tell me if there is a crank to raise the antenna I am missing or hoe to get more then 1 watchable channel without cable
Tdellario is offline   Reply With Quote
Old 07-20-2018, 07:44 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. First you need to determine if you have the type of antenna that can be raised (batwing style) if so look for the crank on the ceiling where the antenna is positioned on the roof. Second ensure that your antenna booster is on look at the switch plate where the cable to the antenna come out of the wall and see if there is a small push to operate switch push it in and see if you get a light. if it already lite the booster is on.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-20-2018, 08:03 AM   #3
If you have one of these then your antenna cranks up and rotates.Click image for larger version
Name:	antenna crank.jpg
Otherwise you might have an antenna like this that can be seen from the ground with a rotate knob on the ceiling.
Old 07-20-2018, 08:44 AM   #4
Head Rambler
Or you could have a fixed bat wing antenna that doesn't raise or rotate.
I just replaced one of those on our RV with the bottom unit that Wiscampsin posted.
Since yours isn't a fifth wheel and you can reach the ceiling, I'd suggest you replace it with a crank up model if you don't already have one.
Gotta go campin!
Old 07-20-2018, 08:58 AM   #5
Mr. Dan's Avatar
I'm interested in your answer to SeaDog's question about the Over The Air antenna booster. It has to be ON to receive any semblance of signal. If ON, are you sure you selected Antenna on your TV before you scanned for channels?
Are you still with us?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 07-20-2018, 01:02 PM   #6
It does not a anything to raise or lower it. And booster is on
Old 07-20-2018, 01:03 PM   #7
I have the 2nd kind but don’t see anything like that to move the position on the ceiling anywhere
