Originally Posted by Larry-NC
If you plug your Android device in via USB, the player should see it as a digital storage device and find the mp3s on it. Could you see if that works? If it does, it ought to work similarly with an iPhone.
Yes I have used the USB to play music from my Galaxy S8 Android and it works great.
Here are specs from MB Quart. First line is Apple support. Also the Usb can charge a device.
https://mbquart.com/rvm2-0/
APPLE® CONTROL
Quick control and access of iTunes collection with iPhone, iPod and iPad.
SOURCE TYPE
AM/FM/Bluetooth®
INPUT TYPES
Bluetooth, RCA, and USB. The USB supports all new technology MP3, WMA, APE, FLAC and WAV files.
BLUETOOTH® CONNECT
Bluetooth® Connect allows your phone or other Bluetooth enabled device to be quickly paired to the controller without a complicated pairing process.
SECURE SIMPLE PAIRING™
Quick and secure wireless connection between your Bluetooth enabled device. This reliable connection is impervious to outside interference, providing a lock-tight connection to your audio system.
QUICK PAIR™
No more frustration with trying to pair. When the unit powers up, it immediately connects to the last device connected. For a first time connection, you only have to select "MB Quart" from your Bluetooth menu and you are connected, QUICKLY.
BUILT-IN POWER
Four channels of output. These channels remain active when running external amplifiers (RCA Output) to run additional speakers in the vehicle.
CONTROL METHOD
Unit is adjusted by master knob and menu selection.
AM/FM TUNER PRESETS
AM: 12 station, FM: 18 station - AM1, AM2, FM1, FM2, FM3 each memorize 6 stations
FREQUENCY RANGE
FM: 87.5 - 108MHz, AM: 520 - 1710KHz
VIDEO INPUT
HDMI Front/Rear, Pass Through
USB / APPLE® / CHARGING PORT
Yes (Front panel, quick charge)
BLUETOOTH VERSION
Version 4.0
DUAL AUDIO ZONE CAPABILITY
Control volume in two different areas independently, such as passenger area and outdoor speakers.
HDMI THRU PUT
All audio and video from satellite or other digital services are pushed to the TV monitor and audio system.
ALARM CLOCK
On/Off Options, Alarm, Sleep, Power Up, Beep
