Old 04-26-2015, 07:48 AM   #11
kdot's Avatar
3M Extreme Sealing Tape
A huge "Thanks" to all who offered advice/answers to my question about this product and where to get it. I ordered a single roll of it from Amazon.com.
Kent
kdot is offline   Reply With Quote
Old 04-27-2015, 09:35 AM   #12
3M 4412N tape is also available by the roll from Grainger
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-27-2015, 09:59 AM   #13
kdot's Avatar
extreme Sealing Tape3M Extreme Sealing Tape
Thanks Poneil; that's a lower price for a smaller amount.
Kent
Old 04-27-2015, 12:25 PM   #14
Also try this Amazon supplier link. Currently $30.27 per 2" roll.
http://www.amazon.com/dp/B007Y7CLHM/ref=biss_dp_t_asn
Tom
2012 Rockwood A122S
Old 04-27-2015, 01:27 PM   #15
kdot's Avatar
Once again, thanks!
Kent
Old 05-02-2015, 09:24 AM   #16
I inspected my 3 year old bubble window,
and, even though I do not believe it is leaking yet, I noticed 2 places where a leak could develop.
Where the long top horizontal strip overlaps onto the vertical side strip, some of the "caulking" at that lap joint has eroded away.
I happen to have some Proflex caulk, and will work that into those joints, and put a small bead around the rest. If a leak develops, I'll go to the special tape.
Thanks for bringing this issue to light.
mickrock is online now   Reply With Quote
Old 05-02-2015, 01:49 PM   #17
kdot's Avatar
Mickrock, you're welcome, although I don't deserve the credit for bringing the issue to light. There are a ton of posts in the forum that predate me by years. But what helps one person also helps another!
Kent
Old 05-02-2015, 08:55 PM   #18
The overlap in the corner joint is the
problem, and I can offer a solution for it.
The horizontal strip of tape is raised over the vertical side strip at the corner, and that raising, especially if done under tension, results in an angled gap that the tape caulk needs to fill. The rain water pressure eventually erodes the weakened caulk at that overlap, causing a leak.
My recommendation is to use a "butt joint" instead of the "overlapping joint". The horizontal strips should cover the top and bottom sides entirely, with the 2 vertical side strips butted against them at the corners.
The only disadvantage is that the butt joints will take more craftsmanship and detail work to complete. Maybe a couple more minutes of time would be needed. This should not be a problem for experienced trades people.
