Old 10-12-2014, 02:42 PM   #1
A-122 water tank repair
Have a short hair-line crack/leak on lower sidewall of fresh water tank on a 2012 A-122. Need to determine what TYPE of plastic the tank is made out of, so that I can figure out a repair scheme.
Typical plastic tank/radiator repair kits will not bond to either polyethylene or polypropylene plastics; hoping the tank is made out of another type of plastic.
Any other ideas on tank repair other than plastic welding??
Thanks,
Tom
tommytraveler is online now   Reply With Quote
Old 10-12-2014, 03:01 PM   #2
Might be worth a try with 3M Extreme tape or eternabond.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 10-12-2014, 04:14 PM   #3
VinceU's Avatar
Just thinking how about a bead of hot glue to a cleaned surface?
Old 10-12-2014, 04:52 PM   #4
1A Camper's Avatar
There are some How To Repair Plastic Kayaks on YouTube that mite help.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 10-13-2014, 12:06 PM   #5
First I would contact FR about a warranty repair, if you are the original owner. Secondarily, they might be able to give you definitive information on the plastic.
FR popup group 574-642-2640
I think you are on the right track in looking for the proper plastic welding method. If that doesn't work out then Big Vic's idea of taping sounds good to me. Drill a small hole at each end of the crack to inhibit spreading and perhaps fill with food grade silicone caulking.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 10-13-2014, 04:51 PM   #6
Anyone try JB Weld for plastic? It is a two-part epoxy product. It may not be flexible enough and I would wonder about toxicity with log term contact with potable water. It is a very durable product though.
Subdriver is offline   Reply With Quote
Old 10-17-2014, 11:06 PM   #7
I used some fiberglass matt with fiberglass bondo on a MH I had a few years back. Never leaked again
sinbad85 is offline   Reply With Quote
repair, tank, water, water tank
