Old 10-23-2018, 10:24 AM   #1
OYO
OYO's Avatar
A-frame Acuator Powered Fix $0
Sorry to start another actuator thread. But I felt a DIY solution might be worthy.
In my very 1st post on this isssue (April of 2016) I posted "Wondering if the existing drive mechanism could be connected to a cordless drill?"
Yes it can and finally I did it. And just using spare plumbing parts out of my shop.
This thing lifts the lid in seconds. No strain on my compact drill (which i carry anyways for the stabilizers).
The buckling issue on the rail is still there. I'm convinced it's because the torsion springs are getting weak. I've ordered gas springs described in backpacker3's thread: 2017 Rockwood A213HW Roof Repair hoping that will eliminate it.
I have step by instructions if anyone is interested.
ID:	189833   Click image for larger version
ID:	189834   Click image for larger version
ID:	189835   Click image for larger version
2016 Rockwood A213HW
2010 Silverado LTZ 4x4 Ext Cab
Craig
OYO is offline   Reply With Quote
Old 10-23-2018, 10:28 AM   #2
Trailer Park Supervisor
NJKris's Avatar
Nice work Macgyver!
NJKris is offline   Reply With Quote
Old 10-24-2018, 10:27 AM   #3
I'd love the instructions please. I've replaced mine once within months of getting the camper brand new. If it happens again I'd rather do something like this and not have to worry about it being a continual problem.
tlspencer is offline   Reply With Quote
Old 10-24-2018, 08:26 PM   #4
We are lucky we never stop working -
Good job Oyo!
I am still using the "put it on for up" and then take it off and put it into storage until the next time to go up.
Your work and sharing of know-how is greatly appreciated.
mickrock is offline   Reply With Quote
Old 10-24-2018, 09:23 PM   #5
What a great idea! I would like a copy of your instructions, please. Thank you so much.
HudsonValley is offline   Reply With Quote
Old 10-25-2018, 07:53 AM   #6
OYO
OYO's Avatar
Originally Posted by mickrock View Post
Good job Oyo!
Thanks mickrock. It goes both ways. I just completed the refer fan mod I believe you contributed to.
Craig
Old 10-25-2018, 08:29 AM   #7
OYO
OYO's Avatar
*The pictures in this write up are an OEM actuator I managed to rebuild after it crapped out, but never used. The one I modified was a Windy Nation.
*-opened the gear housing (screws on the very bottom)
*-removed all the gears. Make sure to keep the pin for the drive shaft
*-searched for something with a female end that would go over the drive shaft and a male end with threads. I ended up using brass plumbing fittings (3/8" ID) and two nuts. The 1st as a lock nut (should be thinner than example), the 2nd as the driver for your socket.
*-drilled a hole horizontally through the female end of the drive shaft fitting (this was the only thing that required much skill), slid the fitting over the drive shaft and inserted the original pin
*-cut the mounting bracket off the bottom of the gear housing with a hacksaw. It's cast aluminium, pretty easy.
*-drilled a hole where the mounting bracket was, large enough for the new fitting(s). The fittings in this example are larger than what I actually used. Either would work, but you'd have to attach the 1st fitting with the pin, put the housing cover on then thread on the nuts.
*-made a new mounting bracket from a boat bilge plug (rubber bushing) and a U bracket and attached it to the bottom of the gear housing. There's many ways you could do this.
*-attached it to the camper
ID:	189937   Click image for larger version
ID:	189938   Click image for larger version
ID:	189939   Click image for larger version
ID:	189940   Click image for larger version
Craig
Old 10-25-2018, 10:21 AM   #8
Head Rambler
Just a thought.
Would an all-thread (threaded rod) coupling work in place of the fittings you show?
Gotta go campin!
Old 10-25-2018, 03:29 PM   #9
OYO
OYO's Avatar
Originally Posted by Bama Rambler View Post
Just a thought.
Actually it was one of the 1st things I looked at. But I couldn't figure out how to attach it to the drive shaft. Maybe someone will. The neat part about mods is how they evolve.
Craig
Old 10-25-2018, 03:50 PM   #10
RV There Yet?
IsleDog's Avatar
you could cut threads on the drive shaft, but that sounds like a whole lot of extra work and you still need to drill and drive a pin through it. i would be worried that without it, your roof would come crashing down when you go to put it away and that fitting unthreads itself.
IsleDog is offline   Reply With Quote
a-frame, frame, power
