was about the placement of the upper mounting hole.
I stated that if the hole is close to the edge of the right angle,
instead of near the angle center axis, then any overload torque
would "ribbon" the side of the right angle.
I couldn't find a pic that showed a detailed top mounting hole,
so I borrowed a gas strut pic to show how the top hole was done for that.
Note that in the pic, the top of the gas strut is mounted close to the angle,
or at the topmost place that it could be mounted. The idea is to maximize
the strength of the right angle and put the mounting point there.
Ok, the pic is of a gas strut, which will not have to apply the torque of an
actuator that is a motor driven unit. But, if the top mounting hole was at
the lower part of that roof panel right angle, it could stress that side of the
right angle.
How can I say that? When I was experimenting with the setup of my drive
unit, I initially put the top hole closer to the bottom. When I tested it, I saw that
the side of the right angle was starting to "ribbon". I immediately stopped
the drive actuator and lowered the drive. The "ribbon" effect straightened
out, and I put a new hole close as I could get it to the center of the right
angle. It works fine, as the torque is applied more to the center axis of the
right angle. Similar to the borrowed pic.
Maybe someone who has had a "ribbon" effect will post a pic of their top
mounting hole, so we can see its placement.
I hope this helps, somewhat.
