Old 07-28-2015, 10:48 AM   #11
Check the forecast for how many consecutive hours you expect to be below freezing before you make a decision on draining the tank or not.
An alternative is to keep bottled water inside the camper with you where you will have heat.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
Old 08-02-2015, 04:29 PM   #12
I've done the following in my T12RSTB:
Grand Teton National Park, October & April/May, several weeks
Temps: high teens/low 20's, snow
Rocky Mountain National Park, December, 5 days
Temps: Low of 9, consistent night time lows in mid teens
Yellowstone National Park, October & April, weeks on end
Temps: Mid teens - low 20s, snow
Not once have I had any trouble with water freezing.
I have thickened up the moulding around the door to seal it better and added reflectix on lots of bare interior areas (not visible areas) including under the bed.
I use the trailers furnace and set it to around 60 when I'm in it in the evening.
[url=http://flic.kr/p/nSZnwE]
rwarrin is offline   Reply With Quote
Old 08-07-2015, 04:35 PM   #13
Nice photo. It looks icy enough there for the camper to simply slip away. Chocks and all.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 08-08-2015, 10:02 AM   #14
Dsfast's Avatar
Nice pic look like spring camping in Alberta nice times. Just a little wet
Dsfast is offline   Reply With Quote
Old 08-09-2015, 09:21 PM   #15
Originally Posted by Annabanana View Post
Hello Forum!
Although it's the middle of summer, I will be camping at high elevations next week and it's predicted that one night might get down to 30 degrees (60s/70s by day). If I have a full water tank and the hot water heater on, should I worry about anything freezing/breaking? There is no outside water connection so will be using only what's self-contained in the TR12B camper.
Thank you!
Anna, How was your trip? Any weather problems?
Tinsu is offline   Reply With Quote
a-frame, camping, frame
