Old 05-19-2015, 10:15 PM   #1
A minor electrical mod
After a particular battery incident a few weeks ago that we need not go into here, a change was in order. So I bought a new battery box and a group 27 battery to extend the dry camping time. I'll be out 4 nights this weekend and want to power my CPAP as well as the normal camper stuff, so its a good test. Here is the battery in the box.
2015-05-18 16.53.30 by b2220128, on Flickr
Because I wanted to put on a battery switch, the box is big enough for a group 31 but has a slide in retainer for smaller batteries. I orders it from Walmart.com where it was stock for same day pickup at my local store. The extra space provides the room for the bolts that hold the switch to the box. I bought a few feet of red 10 gauge wire and the appropriate crimp on ends. I also picked up 3/8 split plastic wire cover to protect the wires.
Here's the switch
2015-05-18 16.53.39 by b2220128, on Flickr
I bought a two position switch to reserve the possibility of setting up an independent power circuit that can be powered while the parasitic drains in the camper are shut off while I am away for the day. Perhaps for a fridge compartment fan.
I installed the wider box by cutting and fitting 2X10 lumber into the battery box rails rather than taking it to the shop and having the rails moved and re-welded. The lumber is attached to the rails and the box is screwed to the lumber and I have a ratcheting strap as a hold down.
The last part of the mod will be to cut and relocate the break away switch power wire to bypass the switch so it can be in the off position while traveling if needed.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 05-20-2015, 07:28 AM   #2
OutAndAbout's Avatar
Nice mod Tom. Adding a battery switch has been on my list for a while, maybe some day I'll get the time. Thanks for sharing. this weekend.
Never try to teach a pig to sing, it's a waste of time and annoys the hell out of the pig.
OutAndAbout
2014 Rockwood A122S
2014 Tacoma 4x4
OutAndAbout is offline   Reply With Quote
Old 05-20-2015, 11:27 AM   #3
That switch on the box is cool.
Doesn't look like you'll be using the furnace for your test trip, although I am looking forward to seeing your review.
Good luck!
mickrock is offline   Reply With Quote
Old 05-20-2015, 11:53 AM   #4
The 30 year average low is 58° with a standard deviation of 7°. But we are dry camping so no furnace for me. Taking my down sleeping bag just in case.
Tom
2012 Rockwood A122S
Old 05-27-2015, 09:36 AM   #5
the trip was a great success. It rained out west in the desert on Thursday with fog and heavy mist on Friday morning. Great fun when passing convoys of pressure pumping equipment. The desert sky cleared up Friday and was sunny the rest of the time. Unlike those unfortunate enough to be in the Hill County or suffered from flooding and loss of power back here in Houston. Or the storms elsewhere.
My battery proved to be insufficient to power my CPAP for four nights. Monday night the battery was too low, so near dead, and I had to use a rechargeable Li+ battery pack. So I guess my system engineering need to go toward providing more recharge capacity.
This weekend would have been ideal for solar, if I could have tied it down securely from the high winds. I'd like to have a rechargeable Li+ battery with a 12V to 12V battery charger that could be powered up by my truck electrical system in the daytime and recharge the camper battery or charge straight from the truck. All I can find is LI+ jump starters that may or may not do well in recharging a deep cycle camper battery. Perhaps I'll get a second house battery next time I dry camp for four or more nights.
Tom
2012 Rockwood A122S
Old 05-27-2015, 03:49 PM   #6
1A Camper's Avatar
If you go solar here is something to look at.
http://www.amazon.com/Renogy%C2%AE-M...le+solar+panel
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 05-28-2015, 07:21 AM   #7
Tom
2012 Rockwood A122S
Old 05-28-2015, 07:47 AM   #8
KyDan's Avatar
Tom, we've run this one up the flagpole many many times but I gotta ask--
Are you SURE your refrigerator doesn't have that dreaded heater strip
between the fresh food door and freezer door??
Many do have it and some don't have a switch to turn it off.
My new rig is one!
It's relatively easy to test. Turn on the fridge and after a few hours put
your finger on the middle of the metal strip between doors.
If it's got the heater you can easily feel it will be warm.
If the heater is absent or off the metal will be cold to the touch.
If you've got the heater it will suck your battery in a couple days.
I just cut the wire to the heater in mine the other day.
We don't care about a little condensation there but do dry camp every so
often.
Peace!
Dan & Rita D
Old 05-28-2015, 11:30 AM   #9
A Frames come with small 3 way fridges that don't have a freezer much less such advanced technology as a heater strip. If the 12V switch is off, which it is all the time on mine, then there is no power draw.
Tom
2012 Rockwood A122S
Old 05-29-2015, 07:41 AM   #10
here is a thought .....
I too use a CPAC machine and have been struggling with the issue for a couple of years when camping off line. What i have done in the past is bring along a Xantex 800 series powerbox, and use this as my powerbase. I didnt have a 12 volt converter so i powered this through the inverter ... yea i know ... its not that efficient... but hey
This will last me a couple of nights. I have a dedicated 40 watt solar panel that plugs directly into powerbox, but some campsites are very sparse for sunlight ... so sometimes this has failed.
Tired of dinking around with the 40 watt panel, i installed a 12volt plug in the trailer that pulls power from twin group of good quality 27 deep cycles ...and i purchased resmed 12 volt converter ... hoping this will do better than the Xantex power box and the 40 watt panel.
Both batteries are topped up with a 80 watt panel during our trips ... and im hoping now that after reading your post that i will have enough juice to get me through a good week of camping when on a sunny camp site.
so .. all in all .. thats what i have done ...
but just a quick question for you ...did you run your humidifier when you went on your 5 night trip .... i dont .. as it is much more of a power draw than the pump itself ..
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 05-29-2015, 04:16 PM   #11
Sounds like you have a good plan
Yes I did run the humidifier because the dry, cold desert air is pretty unpleasant to the mouth and throat with a CPAP. Without the humidifier running, I can use that battery that came with my machine for a full night and recharge from my TV during the day.
If the Anker portable jump starter didn't have a 50% low battery alarm, I'd pick one up and use that for the extra power at night.
Tom
2012 Rockwood A122S
Old 06-02-2015, 08:38 AM   #12
A new device may be of interest at
fundairing.com
Old 06-02-2015, 01:04 PM   #13
Interesting. I've never heard of a "microblower" before. It uses disposable zinc-oxygen batteries and I wonder how much pressure it will be able to provide. While not being willing to do the Indiegogo subscription, I would like to see this come to market.
Tom
2012 Rockwood A122S
Old 06-02-2015, 02:31 PM   #14
yea ... so will i .... thanks for that tho .. interesting ..
you know there are quite a few people with this condition while camping, im surprised only a few of us have mentioned this on the board ...
d-mo
2011 Rockwood A122
Old 06-02-2015, 02:31 PM   #15
sorry ... duplicate post ...
2011 Rockwood A122
Old 06-03-2015, 12:19 AM   #16
handbuilder's Avatar
Sorry, Dmo & Tom, I decided best to delete my post and stay on topic.
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 06-04-2015, 07:41 AM   #17
Thanks for your consideration, handbuilder. But now that we're on a tangent...
I attended an IPO roadshow yesterday by a company, ieCrowd, that among other technologies, is developing a non-CPAP alternative treatment for sleep apnea. The idea is to use an ankle bracelet at night to stimulate the nerves into tricking the brain to "thinking" the wearer is walking. The brain in turn will put more effort into breathing and overcome the apnea. They did not say if it would specifically treat obstructive SA, which is what most of us have. Nor do they give a timeline for a product. But it is an interesting idea that many would like see realized.
Tom
2012 Rockwood A122S
electric, electrical, modifications
