Old 10-17-2011, 06:40 PM   #1
Jeep4Two's Avatar
A Series Spare Tire Mounts
Just a note to all you AFramers.... While modding my camper this weekend (meaning I removed the spare and spare carrier and cut off part of the rear bumper to gain needed inches for storage inside my garage) I found that the lower mounting holes of the spare tire mount were messed up. The two bottom screws appear to be just screwed into the camper shell. They had vibrated loose, and one was missing and the other almost completely out.
The one that was missing will need some TLC to get a replacement screw in as the hole is stripped out and enlarged now. I'll have to fashion an insert or something, maybe use one of those plastic drywall screw in anchors. I figure a liberal coating of caulk or silicone sealant With the anchor to secure it, then a generous shot of silicone sealant in the screw hole when replacing the screw should suffice.
The hole left by the missing screw was large enough to allow a notable amount of water into the camper if left unattended over time, and it would just rot between the shell and inside wall...
Note: I'm making a bracket to reattach the rear bumper when traveling. I figure without it I might have a backing accident that would be much more costly than with.
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 10-17-2011, 09:37 PM   #2
Mostly Harmless
thehamguy1's Avatar
Whoa! Thanks for the heads-up!
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
