Old 09-29-2011, 11:09 AM   #1
Mike G's Avatar
A122 By-Pass Valve
My camper is packed for my next trip and I am lazy and don`t want to open it right now in the rain that has not stopped for 40 days.
Does the hot water heater have a by pass valve from the factory? I was thinking about this because I know whats coming shortly(Winter) and I have to winterize the camper soon. I blow the lines and run anti freeze so I was just curious about this. Thanks for any answers....
________________________
2012 A122 (SOLD)
2016 A122 SXR (New)
2016 Toyota Tacoma DCLB
Mike G is offline   Reply With Quote
Old 09-29-2011, 11:52 AM   #2
Most of them come with a bypass valves, or valves. Don't for get to pull the plug on the outside bottom of the water heater and drain it also.
If you search on here for winterize, water heater valve, etc., you will find this gets asked a lot, and is covered well in other post, complete with diagrams.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-29-2011, 12:22 PM   #3
TURBS's Avatar
windrider is right the only thing I have to add is it could be a 3 valve bypass or it could have a single valve bypass .
I also seen on a post not to long ago an "a" series camper that did not have one installed.
Old 09-29-2011, 01:33 PM   #4
Jeep4Two's Avatar
My A126 has a 3 way bypass valve system. It's mounted on the piping inside the camper under the driver side dinette seating. Just lift the cover and you will see the three valves. Close the two closest to the heater (just by the inlet and outlet) and open the one that connects the two inlet and outlet pipes.
I haven't done it yet but should be valve perpendicular to the pipe for closed, parallel (inline with) the pipe for open.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 09-29-2011, 04:48 PM   #5
My A122 is the same.
Currently trailerless.
2014 Silverado Double Cab 1500 5.3L V8 w/3.42 Axle Ratio Tow Vehicle
Sold: 2012 Rockwood A122 Hardside Popup
daveinpickerington is offline   Reply With Quote
Old 09-29-2011, 11:54 PM   #6
Mike G's Avatar
Thanks for the info.! That will help when I get to winterizing my camper.
2012 A122 (SOLD)
2016 A122 SXR (New)
a122
