Old 06-21-2014, 03:26 PM   #1
Happy AFrame Campers
yayus's Avatar
A122 Solar Panel - Wiring and Mounting Ideas for the Controller
Hi Folks. Hope everyone is enjoying a great 2014 camping season!
We just purchased a solar setup for our A122 from SunpowerLink, sunpowerlink on eBay and thought we'd check in with the group for ideas about wiring.
Specifically, we'd like to install the controller in our electrical compartment, then route the connections through the front wall, if possible. We want to avoid drilling holes in our A122, and there may be a path under the front face plate. Has anyone run internal-external wiring in this section of the AFrame? If too much of a pain, I may devise a way to mount a little plastic utility box on the battery rails, as the solar controller is tiny (but not waterproof.)
Thanks again for any thoughts!
2013 Rockwood Premier A122
2006 Chevy Silverado 1500, Vortec V8
Northern California, Wine Country
yayus is offline   Reply With Quote
Old 06-21-2014, 09:13 PM   #2
yayus's Avatar
No worries if there's not huge interest in this topic ... I'll likely make a storage container for the solar controller by cutting down a battery box and attaching it to the battery rails.
Thanks much to all the forum contributors for this great resource!
Old 06-21-2014, 09:13 PM   #3
Solar charger works for me!
My A122 had a solar panel mounted on the front of it when I bought it.
I have to admit that I was skeptical about it, at first, but it seems to be keeping the battery in good shape. The solar panel wire is routed down to the tongue and then to the battery where the control box resides, inside the battery box, and on top of the battery.
My 12v use is mainly for the tongue jack, so I am not draining the battery much.
When the controller led light says "charging" the overall voltage is just over 14, which is good.
I like it.
Good luck with yours.
mickrock is offline   Reply With Quote
Old 06-22-2014, 07:57 AM   #4
to the original poster .. how many watts is your panel?
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 06-22-2014, 12:10 PM   #5
yayus's Avatar
Greetings. My panel is 60W. We may add a matching panel later on, but most of our camping is sunny weather and we try to be cognizant of our battery (Type 27) usage. We also carry a spare battery. Thanks.
Old 06-22-2014, 05:55 PM   #6
I have 2 60w panels that I purchased fron sunpowerlink. I have been using them for about 3 seasons and I have been really happy with them. I mounted my charge controller to the wood box that houses the power cord. I ran wires to he battery through the existing conduits. I routed the wires out to the panels out through the port that houses the Main power plug in. I have enjoyed the flexibility of being able to move my panels throughout the day.
bouldercamper is offline   Reply With Quote
Old 06-22-2014, 06:14 PM   #7
yayus's Avatar
Panel and controller wiring connections
Thanks bouldercamper. I actually got the idea to buy the hardware from sunpowerlink based on your earlier posts. Jim Yu is great to work with. As noted above, another 60W panel may be in our future.
If you would, please elaborate on "I ran wires to the battery through the existing conduits." -> Was this through a hole or port somewhere in the electrical area?
Also, "I routed the wires out to the panels out through the port that houses the Main power plug in." -> Did you remove the AC plug connector to do this, or just loosen it?
Thanks again for the recommendation, too!
Old 06-22-2014, 07:05 PM   #8
Roger that on Jim Yu. Walked me through my connection. Highly recommended.
SFC USA RETIRED
2014 FJ Cruiser
2014 T12DDST
Its Cute but......
Total (2104-2017) 319 2018 (42)
dts3204 is offline   Reply With Quote
Old 06-23-2014, 08:30 AM   #9
Mostly Harmless
thehamguy1's Avatar
The older Aframes don't have the same type power connector yours does. The '11s and '12s just have a port in the side of the camper that the power cord pushes through and tucks back in through when done camping. That port--a hole with a flip cover identical to the one over the external gas connector--is where I ran my solar panel feeds in from. I think bouldercamper did the same.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 06-23-2014, 11:17 AM   #10
yayus's Avatar
Thank for the good info, folks. We'll either create an external enclosure for the controller, or make use of the wiring port in the trailer floor beneath the electrical area. Cheers to all.
a122, controller, mount, solar, wiring
