Old 06-28-2015, 06:22 AM   #1
A122s furnace ok to use w/ 20 amp
Hi all,
I've searched and searched the forum but couldn't find a clear cut answer (at least to me!!) for this.
We will have a 20 amp hook-up for a week in Maine and it will be chilly at night. I know I can't use heat pump/ac, but can 20 amps power the propane furnace (Suburban NT-26SEQ) safely?
Thanks!
mmanley1 is offline   Reply With Quote
Old 06-28-2015, 06:52 AM   #2
Oh sure. No problem whatsoever. It depends on your converter, but typically it won't pull more than around 8-11 amps full out off your 20amp 110vac line.
rana is offline   Reply With Quote
Old 06-28-2015, 06:55 AM   #3
You should not have a problem running the furnace. It runs from 12v for the fan and the propane provides the heat so the draw on the 20amp AC is low. The furnace only pulls 10amp DC that is around 1 amp AC.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 06-28-2015, 07:19 AM   #4
Thanks for quick responses! My wife will be happy and, by association, so will I!
Old 06-28-2015, 07:38 AM   #5
If you want, we could tell you "no" so you can catch a little cuddle time.
a122, furnace
