Old 03-06-2016, 09:04 AM   #1
chuck9997's Avatar
A122s Sheet Size
I know they say the bed in my 2014 a122s is a queen.. but it's kinda an odd measurement. I used a queen fitted sheet.. and it seems very loose fitting. Has anyone tried full size sheets?
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 03-06-2016, 09:13 AM   #2
It will have an rv queen (short queen) 60" x 74" ( std queen is 80")
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 03-06-2016, 02:08 PM   #3
In our A122, the thinness of the stock mattress also affects the fit of the sheets - and made the bed quite uncomfortable for a night's sleep. We added foam toppers to both the bed and dinette, and now they both sleep wonderfully. And the extra thickness makes the sheets fit better.
I would measure the actual bed size, and get as close as you can. The A-frame beds that stretch across the width of the camper are generally 80" long, so an extended full or extended twin sheet is necessary if the bed isn't the standard queen 60" wide.
just our experiences
Fred W
2014 Rockwood A122 A-frame
Old 03-06-2016, 03:16 PM   #4
A122's have a full size (54'x80') bed.
2015 Rockwood A122SXR
2006 Toyota Tundra Double Cab 4x4
biscuit72 is offline   Reply With Quote
Old 03-06-2016, 04:31 PM   #5
chuck9997's Avatar
54 x 80 is kind of a full/queen. 54 is full width, 80 is queen length. I think a full fitted sheet will fit better and more snug. The queen fitted is just too loose.
Old 03-06-2016, 05:28 PM   #6
It's considered a Full XL. I replaced the stock mattress with a 7 in thick foam mattress and use a full size fitted sheet. Used full on the stock mattress as well.
Old 03-06-2016, 06:16 PM   #7
I had trouble finding anything locally, but have some of these "full XL" sheets from Amazon and really like them: Robot Check
2014 Rockwood A122BH
2017 Nissan Pathfinder
bensinc is offline   Reply With Quote
a122
