Old 04-08-2013, 03:33 PM   #1
N5RV
daijari's Avatar
A124S Grey Water Adapters?
I've searched here and on Google and I have not had any success. I am looking for some sort of adapter that would allow me to drain the grey water from the sink and shower of an A124S, to a standard RV drain commonly used at an RV park. I am operating on the assumption that RV parks do not like you dumping grey water on the ground. I recently purchased my 2013 Rockwood A124S, and I am really looking forward to getting it out on the road once I can get all the accessories for it.
TIA,
Jerry
Jerry, Radio Amateur N5RV
FR Rockwood A124S
2013 Toyota Tundra Double Cab 4x4
daijari is offline   Reply With Quote
Old 04-08-2013, 04:14 PM   #2
Presuming you drain the grey water with a garden style hose, you can use one of these.
Grey Water Drain Adapter
It slips into a rubber or foam seal then into the park sewer system.
Before I had one if these in my old pop up, I ran a short piece of hose into the drain and stuffed some paper towels into the drain to arrest the odor. When I left, the paper went down the drain and the end of the hose was cut off and put in the trash. Some RV parks will not let you use a hose the way I did so it is best to plan ahead
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-08-2013, 04:16 PM   #3
N5RV
daijari's Avatar
Thanks! I am looking for what looks like a reducer. The grey water outlets on the A124S looks to be 1.5", and threaded.
FR Rockwood A124S
Old 04-08-2013, 04:37 PM   #4
I never even thought to check the service side attachment needed while shopping. I had a right angle reducer that went when I sold my pop up. It converted from the 1.5 inch male pipe thread outlet to to a male hose thread.
Tom
2012 Rockwood A122S
Old 04-08-2013, 04:40 PM   #5
N5RV
daijari's Avatar
I'll see if I can find one at the dealer or at a hardware store. Much appreciated!
FR Rockwood A124S
Old 04-08-2013, 04:48 PM   #6
Is this what you are looking for?
Valterra T01-0091VP 1-1/2" x 3/4" 90° Drain Connector
Tom
2012 Rockwood A122S
Old 04-08-2013, 04:53 PM   #7
N5RV
daijari's Avatar
Sweet! That's what I was looking for! I pretty much suck at searching for discreet items such as this....
Thanks again!
FR Rockwood A124S
Old 04-08-2013, 04:58 PM   #8
N5RV
daijari's Avatar
And here is the last item I need since the shower and sink are separate outlets.
Y Washing Machine Mixer Hose
FR Rockwood A124S
Old 04-08-2013, 05:37 PM   #9
Your welcome. I just happen to know what it was.
You can use any metal Y adaptor without valves from the hardware store. Cut hoses to the specific lengths you need to reach place you want the adapter to be. Or even a T adaptor to have the hoses join where one drops to the ground. But since yours are close together that idea should work fine.
From my days as a pop up owner, I would think the best arrangement would be for the connector to be as low as possible to give the low shower pan drain the greatest head possible for drainage and lowest chance for a backup from the sink. But I don't know your specific configuration.
Nice ride BTW.
Tom
2012 Rockwood A122S
Old 04-08-2013, 05:52 PM   #10
N5RV
daijari's Avatar
I'll keep that in mind, Tom! Thanks for all your help.
FR Rockwood A124S
