Old 04-29-2013, 01:19 AM   #1
A128 screen door
Well here is my second try at the screen door. the first on opened to the in side not very good when putting up and down. I did this last summer and it worked well .I picked up a used screen and resized it added a header used the upper and lower hinge that are on the main door Click image for larger version
jlroadmaster is offline   Reply With Quote
Old 04-29-2013, 06:26 AM   #2
Also an impressive looking mod.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-29-2013, 09:42 AM   #3
Mostly Harmless
thehamguy1's Avatar
You have an innovation there that would attract numerous customers, myself included. You're obviously handy with metalworking tools. Do you notice any less stability in the door itself since you borrowed two of its hinges for the screen? Did you pop rivet the hinges to the screen frame? When the camper is folded, does the screen door contact the sinkside A-wall under it? Did you come up with an alternative to the plastic turnbuckle on the upper door (I notice it's gone now) or did you just eliminate it?
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 04-29-2013, 11:35 PM   #4
[QUOTE=thehamguy1;363199]You have an innovation there that would attract numerous customers, myself included. You're obviously handy with metalworking tools. Do you notice any less stability in the door itself since you borrowed two of its hinges for the screen? Did you pop rivet the hinges to the screen frame? When the camper is folded, does the screen door contact the sinkside A-wall under it? Did you come up with an alternative to the plastic turnbuckle on the upper door (I notice it's gone now) or did you just eliminate it?[/QUOTE yes I pop riveted the hinge to the screen we have not had any problem with the hinges and I removed the turnbuckle not sure what it did than get in the way we never used it to lock the door top I installed some earth magnets top and bottom of upper door
