Old 11-10-2012, 12:39 PM   #171
Yukon Don's Avatar
Originally Posted by thehamguy1 View Post
A question: did you wrap any kind of protective cover around the trailer connector to cut down on the possible corrosion? It just dangles out there now and it'll get buried in the snow during the winter. I think I'll go out and tuck it away, maybe tape a Baggie over it.
I thought about going that route last winter but I was concerned about the baggie holding in moisture. If you're going to do that, I'd suggest ensuring everything is dry as a bone when you do it and tape everything down tight.
I just smeared silicone grease on mine. Seemed to work fine last winter with the A-lite.
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 11-13-2012, 08:33 PM   #172
ko777's Avatar
I'm counting the months before my next trip...it has been over a month since my last trip...only four more months for my next season. My first season camping with my A128S have been documented in this thread. With all the information you shared here made my learning experiences with the trailer awesome, from picking it up from the dealer, and everything between the trips to winterizing and storing my trailer.
Here are the final tasks I did last week, remove the battery and stored it in the house. Removed the propane hose and put a hard cover on the propane tanks. Put the 7 pin plug and cable in the propane hard cover. Check under the trailer for any wild animals trying to move in there.
No wild animals under there yet
Secured the battery container and propane tanks with bike cable locks. The propane hard cover is secured by the locked bicycle receiver.
Before I hibernate for the winter I have a couple of more questions about the battery. I tested the battery voltage and it was 12.73 volts. Here is battery chart posted earlier in this thread:
After 4 weeks my battery is still 100% charged according to the chart. When do I start charging the trailer battery stored in my house? Should I base it on the voltage of the battery before charging?
I do not have a battery charger, what kind do you recommend?
ko777 is offline   Reply With Quote
Old 11-14-2012, 07:51 AM   #173
Mostly Harmless
thehamguy1's Avatar
What I've used on my motorcycle batteries for years and intend to use for my dual camper batteries is a charger that goes by the brand name of Battery Tender. http://batterytender.com/?gclid=CILy...FegWMgodQ2MAxg It has a four level charge feature that will sense the level of charge your battery needs and once it's charged it will maintain that level as long as it's connected. Before I got mine several years back, I couldn't get my motorcycle batteries to last more than two years. Once I used the Tender battery life jumped. I currently have an 8-year old battery in my cycle and it shows no sign of quitting. I'm hoping for similar results with the camper batteries. Not 8 years maybe, but more than 2.
You hook up the Battery Tender, plug it in, and forget it. If your battery needs charging it goes into "bulk" charge mode until a sufficient level of charge is reached, then it tapers off to an intermediate charging level, and finally switches to "float" mode. Being a low-amperage charger it's best if you start using it while the battery is full.
I paid nearly $40 for my "junior" model and it doesn't look like it should cost that much. It's a wall wart and cables. But given how well it works I'm not complaining. Canadian Tire is supposed to carry Battery Tenders. I've heard that places like Wal-Mart have similar units for a lot less. I don't know if they're any good; maybe someone else here has experience with them.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 11-14-2012, 07:56 AM   #174
Where did you purchase the tank cover? Which one? If online, can you provide a link? I have been thinking about getting one.
Tinsu is offline   Reply With Quote
Old 11-14-2012, 04:00 PM   #175
Mostly Harmless
thehamguy1's Avatar
This might help: http://www.campingworld.com/shopping...nk-covers/3953. They want $25 for it plus $15 to ship it--ridiculous!
Amazon sells the same cover for $28 but with free shipping: http://www.amazon.com/Camco-40523-Pr...sim_sbs_misc_3
2011 Rockwood A128
60W solar system
Old 11-14-2012, 07:16 PM   #176
ko777's Avatar
I got my cover as part of the package deal for my trailer. Thanks THG1 for providing the links.
Old 11-15-2012, 09:59 PM   #177
Jeep4Two's Avatar
My vinyl cover has lasted a year, and I think this nice molded unit is in my near future. The cheap vinyl cover is always discombobulated when I arrive at the CG or home....
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 11-15-2012, 11:57 PM   #178
ko777's Avatar
Great to know your battery maintaining experiences and thanks for the links. I have a couple of ebikes that uses a 48V setup, 4x12V connected to make 48V. Both batteries got destroyed because the chargers that came with it somehow did not get the signal to stop charging, that cost me $300 and it happen again so another $300. This problem is so unpredictable, to avoid this issue I used a timer every time I charge my ebike batteries, at the most for 5 hours.
Should I take that chance again leaving the trailer's battery charging all the time?
If I check the battery strength level every month then only charge it if the level goes down by 10%, will this shorten the battery's life?
So far my ebike batteries (2 summers old) are doing great, using the timer to control charge time. I will do the same when I charge the trailer's battery I'll be using a timer too.
Old 11-16-2012, 09:05 AM   #179
Mostly Harmless
thehamguy1's Avatar
I think what kills lead-acid batteries is letting them sit discharged for a time, especially if it's cold where they are. Overcharging kills them too, as you said. So the timer idea should be ok for your camper battery.
The expert on battery and general maintenance issues is Lou Amato (hope I have that right), who goes by the user name of herk7769. He posted info and links about battery maintenance last year; I found them quite helpful. You should be able to find his posts about the topic using the forum's search function.
2011 Rockwood A128
60W solar system
Old 11-17-2012, 02:14 PM   #180
ko777's Avatar
Here is the link of FAQ re battery posted before:http://www.windsun.com/Batteries/Battery_FAQ.htm#What
I got a charger on sale today. I will still monitor my charging monthly, I don't want to destroy another battery because of over charging due to Murphy's law. Here is the charger I got for $23:
I hope this works out for my battery
a128, a128s, aliner
