Old 03-23-2013, 06:45 PM   #241
Yukon Don's Avatar
Originally Posted by thehamguy1 View Post
The only thing I can think of is not to drag the tarps off your roof. There might be abrasives that have worked in there over the winter (dust, sand, dead moose, the usual) and you wouldn't want to scratch the skylights. Might be best to bring the sides of the cover up and then roll up the cover on top before lifting it off.
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 03-24-2013, 08:55 AM   #242
Mostly Harmless
thehamguy1's Avatar
YD! You're alive! Ain't seen you around these here parts much lately, Sheriff.
It's never too late to have a happy childhood!
Lee, WU0V, and Courtenay, N0ZDT
2011 Rockwood A128
2000 Silverado 1500 pickup
60W solar system
2000W inverter generator
thehamguy1 is offline   Reply With Quote
Old 03-24-2013, 10:43 AM   #243
ko777's Avatar
I think Manitoba is still buried with snow, his rig is lost in it lol. Looks like this coming long weekend I could unwrap my rig, thanks for your tip I'll gently remove the cover. Yes, I was wishing for a dead moose but no luck lol; I could have use the head for a trophy.
ko777 is offline   Reply With Quote
Old 03-24-2013, 07:53 PM   #244
Yukon Don's Avatar
Been hibernatin'.
ko -I envy you if you can start unwrapping things this weekend.
I'm anxious to get at mine if for nothing other than sheer curiosity how she weathered the winter.
Old 03-29-2013, 03:21 PM   #245
ko777's Avatar
Well it looks like the start of the long Easter weekend is perfect for unwrapping and getting my trailer ready for this season. It is still cool about 10C or 50F but nice and sunny in my place.
Too bad for you YD, I hope your rig survived the mean weather in your area.
I was hoping to camp at my friend's lot out there this weekend but it is still buried with snow.
Before unwrapping pics:
Most of the snow at my place has melted.
Happy Easter Weekend!
Old 03-30-2013, 10:31 PM   #246
ko777's Avatar
Finally after 2 gorgeous days, nice but cool weather, my A128S is unwrapped and parked on the driveway. There were no surprises found in the trailer. It actually still smells new.
I was a bit nervous moving it but I managed to get it out my front yard and parked on my driveway smoothly, all that practice last summer helped.
The tarp cover survived the sharp corners of the trailer,no scratches on the rig's surface and bubble windows. I think I'll use this cover again this winter.
Lol the smoke alarm was still beeping so I removed the 9 volt battery. I had to install the main battery for the electric brakes but removed the fuse after it was parked on the driveway.
The tires lost some pressure especially the spare was down to 40 psi, so I inflated all of them to 65 psi.
The stabilizer jacks were not easy to crank up with the cordless drill so I had to do the old fashion manual way. I'll have to spray them jacks with oil soon.
I tested the front tongue weight without the propane tanks and got 340 pounds, wow not much to spare from the 350 pounds max my TV can handle, not happy.
Opening and closing the trailer was still smooth and easy, I just have to get use to the order, I mess up the first time with the doors.
Oh my gosh so many keys to choose from, looks like I have to try 2 or 3 times before unlocking those locks. I have over 9 locking things...lol
Here are some of the pics I want to remember from this experience:
First time unwrapping, still looks new
ID:	26757Click image for larger version
Tarp cover and straps to be reused
No surprises inside, smells new and open with ease
Tennis balls and peg to hitch precisely
ID:	26761Click image for larger version
A128S is front heavy, boo
All parked and just waiting for my first trip this year
I actually enjoyed unwrapping my trailer for the first time. I found no problem with it but I still have to test the water system and see if the blow out winterizing process worked.
Happy unwrapping 2013!
Old 03-31-2013, 09:36 AM   #247
Mostly Harmless
thehamguy1's Avatar
Congrats on having done a good job of winterizing it. I'm getting anxious to do the same here. I had an idea about testing the water system for the first time after the winter. I'm going to take some thirsty towels and put them under the sink area on the shelf and on the floor inside the cabinet before trying the system. And I suppose it might be a good idea to have the compartment under the portside dinette seat open then too, since there's a couple of water lines that travel through that area. If there's a leak I'd hope to catch it right at the start rather than after the floor's flooded.
I started the cleanup of the tongue and underbody area, which were badly dinged up by all the travel on gravel last summer. I used a wire brush to clean the rust as much as I could, then some black gloss Rustoleum spray paint, and it looks almost like new. Nice to know that a little elbow grease can have such good results.
2011 Rockwood A128
60W solar system
Old 03-31-2013, 11:29 AM   #248
Would part of the spring ritual include sanitizing the water system? The manual recommends a bleach treatment before first use and after extended periods of non-use. Or is this overkill or what seems to me to be a tendency these days to error in the extreme on the side of caution? I suppose if there was some standing water in the system for a while or a hook-up to a questionable supply it would be good reason, but otherwise?
ExTenter is offline   Reply With Quote
Old 03-31-2013, 06:14 PM   #249
ko777's Avatar
Since I do not drink the water from the tanks, flushing a couple of times should be good enough. On my trips I use the water tanks and drain most of the water by leaving the thingy spout open on my trip back. Chlorine is another way to kill those bacteria.
Good idea about checking all the waterline for leaks and using lots of towels just in case. I plan to keep the glass/plastic filter container intact and just make sure it is tighten well. I still have the original filter and I have no plans on using it anytime soon.
THG1/Lee after all the mileage you put in your rig, what else got loose besides your microwave oven cabinet? I want to have a routine tightening up all the screws, nuts and bolts of the trailer every after a long trip. Luckily I caught a couple of screws loose on my bike carrier but unfortunately lost one. To make sure this does not happen again I wrap electrical tape on all the screws.
I did check the nuts/screws of the spare tires front/back and the nuts behind the main tires, they were still secured. I plan to use my digital torque wrench to tighten the tire nuts to 100 pounds soon.
I checked all the trailer lights too. Electric brakes are working fine. How do you check if our LP/CO detector is working? Is there a test button like the smoke alarm, I'll check this out tomorrow since my trailer is unwrapped already lol.
Propane lines needs checking too. I got three empty propane tanks, so far Costco is the cheapest place to refill that I know off. Did you know you don't have to be a member to buy things there. Just ask one of your friends that is a member to get you gift cards, $25 is the smallest, and you could buy more than that and use one gift card at a time. Lol I still have two $25 cards left. I was a member before but go there less than 6 times a year, so I cancelled it.
There are still a lot of checking and testing before my next trip. I plan to camp like my trip#4 on the last weekend of April for 3 nights. I'll get to use my new 2k generator which I have not test yet.
Old 03-31-2013, 07:25 PM   #250
DGrissom's Avatar
Originally Posted by ko777 View Post
... How do you check if our LP/CO detector is working? Is there a test button like the smoke alarm, I'll check this out tomorrow since my trailer is unwrapped already lol...
I don't know the correct way to test the detector. We had a mildew problem in the refrigerator this weekend. The door closed itself after our last outing and it was pretty nasty. We cleaned it out and decided to give it a quick shot of spray disinfectant to sanitize it (only thing we had at the campsite).
The next thing we know a detector alarm is blaring away! I jumped up and jerked the battery out of the smoke detector and the sound kept coming?! I had never messed with the CO/Propane detector. I felt around it in desperation, as the noise was waking up the folks in the neighboring campsites, and found a recessed button that shut off the alarm. I don't know if the detector will properly check carbon monoxide. I do know its a whiz bang Lysol detector.
David and Jo Ann G. (& Kenzie the Sheltie)
Prattville, Alabama
2018 Flagstaff E-Pro 19FD "Phoebe" 18 Nights!
2012 Rockwood A128S "Rocko" 200+ Nights!
Nights Camped 2012 - 2017 = 226
Nights Camped 2018 = 0 as of today)
DGrissom is offline   Reply With Quote
a128, a128s, aliner
