Old 04-07-2013, 10:17 AM   #261
ko777's Avatar
Originally Posted by gregory View Post
Raising the camper tongue a little more than an inch shouldn't adversely affect towing in any way, or create sway.
The positive will be in that the camper jack won't be as prone to drag. The fridge will be fine as well.
Campers and trailers are built tongue heavy. Your TV will still have the same "squat" as before.
Are you having concerns other than what's mentioned above?
Deb
Yes, the sway factor is something that I have not experience yet. Pulling my rig from my last trips were great, no issues going 120 kph but I go 100 kph mostly.
WDH was also a consideration but I decided to hold that because my TV only sags an inch at the rear and .25 inch raise at the front.
I double checked my receiver load capacity and it is rated 3500 load and 350 tongue weight also the ball mount checked out too.
I'll be doing a lot of testing on my next trips and get more experience RVing because I'm planning to do a solo trip to the east coast this summer; my goal is to visit all the provinces on that trip and survive lol. I'll start a new thread for my east coast trip and hopefully get some campsite recommendation for each province.
ko777 is offline   Reply With Quote
Old 04-08-2013, 09:34 AM   #262
Originally Posted by ko777 View Post
What is better for the stabilizer jacks, grease or spray oil?
I used spray silicone on my popup stabilizers on the theory that silicone does not hold road grime like grease does. The down side seemed to be the need to re-lube often.
I'd like to hear others experience with lithium and grime accumulation. It may not matter since the parts are not under much stress so the grime doesn't cause excessive abrasion.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-13-2013, 11:34 AM   #263
ko777's Avatar
From my friend in Facebook...lol
Two more weekends before my next trip and Winter is still here, WSUP with that.
Still preparing my rig...
Old 04-13-2013, 09:58 PM   #264
Hahaha...we leave in three weeks. Wish winter would die.
nannylou922 is offline   Reply With Quote
Old 04-14-2013, 02:54 PM   #265
ko777's Avatar
Winter like temperature here this weekend just puts a hold on doing stuff with my rig. I wanted to test the 2k GEN I got last month, I noticed an oil residue at the bottom of it, just from being stored. Anyone know what this tube is for? Here is a pic of it, I exposed the tube:
Old 04-14-2013, 06:12 PM   #266
what angle is that from?? ... looks like the bottom end .. can you give us the make of the gen-set?
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
Old 04-14-2013, 06:22 PM   #267
ko777's Avatar
Checkout post 238 of the link here:A128S Converted from ALINER Ranger
Mine is a Champion 2k but they are the same guts as in the pic.
Old 04-20-2013, 10:43 AM   #268
ko777's Avatar
What's going on with the weather at my place, weekend is here and it is still cold 2c or close to freezing. This will REALY slow me down preparing the rig for my first 2013 trip next weekend.
Anyways I did some online shopping for a BAL leveler, I finally got one good for Canada orders:http://www.sportsmansguide.ca/net/cb...r.aspx?a=74223
I join the club so I could get 10% savings plus $10 coupon*2 for my first order. As soon as I get my club membership I'll order the BAL....
I got so many stuff to test and check on my A-Frame, this is now becoming a challenge....wish me luck
BTW tested the GEN 2K worked fine but failed when the heat pump was turned on. The tube that goes at the bottom leaks small amount of oil, just put a rag under it during transit.
Old 04-20-2013, 05:21 PM   #269
Yukon Don's Avatar
....wish me luck
Done.
I'm glad you posted that link. I've been looking for one of those myself.
2 degrees C ? Pretty bad when Toronto and northern Manitoba are sharing the same weather...
2009 Jeep Wrangler Unlimited
2012 Flagstaff T10RD
Yukon Don is offline   Reply With Quote
Old 04-21-2013, 09:04 PM   #270
ko777's Avatar
Thanks, I got some luck today, the sun was out and it was perfect to do some tests and preparation on my rig. I'm posting pics to remind me what was done and for future reference:
Turned off bypass, got this pic from Gregory's post
Connected main battery, charge is still good after charged last month
Hooked up the propane tank and tested furnace and check how much battery it uses
Furnace fan uses 44 volts, easily drains the battery on cold nights
Filled up with coconut drinks and bottled water, tested propane power to the fridge
Tested electric power but can't tell if is working but propane works fast and very obvious
Tested all the lights except for the signal lights, I will do that next weekend before my trip.
Tested propane stove, all 3 worked fine.
Remove the legs of the front dining table
Three bins fits perfectly under the table, this will be for cloths and stuff. On the other side, shoe mats for shoes. It is easy to slide the bin out without lifting the table, the hole in the corner could be use to push the bin.
During transit, all the cushions are put in front and a lot of soft stuff could go on top, my HD TV box goes here
Tighten all these screws and the other side too, one screw actually fell off but found it
All the heavy stuff on the rear, the open spot is for my GEN 2k
Placed 3 bins in the front storage so I don't have to reach to the bottom for stuff
Installed a new 5" rise ball mount, I had 2 5/8 rise before but the front was still low, I have to take new level readings next week. The capacity of this is 3500 lbs and 300 lbs tongue, I may go over by 50 pounds, I'll watch out for blending on my trip, so I'll bring the old mount with me.
Inflated all the tires to 65 psi
Have not tested the water system but the water pump works fine
As you could see I'm almost ready for my next trip this coming weekend.
Happy Spring Camping!
a128, a128s, aliner
