Old 03-08-2014, 12:35 PM   #441
Herk7769's Avatar
Originally Posted by ko777 View Post
Looks like the same info I got in this link https://www.rv.net/forum/index.cfm/f...d/14265335.cfm
I just got a call back from a RV shop telling me that the there is a TW rating for a TV with or without WDH, is this true?
It can be. It depends on the hitch receiver. If there are two different numbers it will be in the owner's manual or on the hitch receiver itself. Not all receiver's have 2 numbers as it totally depends on the hitch receiver's construction.
Common Weight Distribution and Sway Control Questions | etrailer.com
My 2008 GMC 2500HD Sierra's hitch has a rating sticker that shows the hitch's carrying weight of a 7500 pound camper with a maximum tongue weight of 1000 pounds. With a WD head, the receiver can tow a 13,000 pound camper with a 1500 pound tongue load.
It is also important to understand that that is the Hitch Receiver's rating and NOT the truck's. Just because the hitch can take it does not mean the truck can. What you can acutally tow is determined by the LOWEST rating of all your equipment.
Remember also that any cargo or passengers carried AFT of the rear axle counts against tongue weight.
Hope that helps.
HAM CALLSIGN - KC3FFW
Old 03-08-2014, 02:56 PM   #442
ko777's Avatar
A128S Converted from ALINER Ranger
The confirmation I got from here and from the Internet, the WDH will not solve my TW problem.
There are different TW ratings with or without WDH on my TV as indicated from the info I got from the Internet
Name:	ImageUploadedByForest River Forums1394311843.169973.jpg
The WDH gives 400# TW but that is not enough for approx 600# TW I need.
Oh well, I'm SOL using WDH but this saves me $800 from getting one.
ko777 is offline   Reply With Quote
Old 03-08-2014, 03:00 PM   #443
Herk7769's Avatar
Those are hitch ratings; not your tow vehicles ratings.
You still can not exceed those regardless of the hitch receiver you install.
For example, buying a hitch receiver rated for 25,000 pounds will not make your F-150 capable of pulling that.
Old 03-08-2014, 03:15 PM   #444
ko777's Avatar
I am still getting use to the improvements and changes they did in the FR app. Since this thread has over 20 pages of information, I go back here for references to help me with my AFrame. I just found out an easy way to jump to other pages easily
Name:	ImageUploadedByForest River Forums1394312795.226347.jpg
On an iPhone, tap the red title of the thread, this is what you get
Name:	ImageUploadedByForest River Forums1394312871.097472.jpg
Viola, tap the page you want, also you could use the swipe action to go to the previous or next page, I like that too.
Too bad the pages in this app does not match the browser view pages.
Any link where we could find hints using this app?
Good job creator of this app, looking forward finding other hidden goodies...
Old 03-08-2014, 03:20 PM   #445
ko777's Avatar
Got it and thanks for your info, I'm not getting a WDH for my TV.
Old 03-09-2014, 05:15 PM   #446
only have less than 3" on both side of my TV. I hate the idea folding the side mirrors of my future TV before going in the garage, solution get a bigger garage lol.
Power folding mirrors. I push a button every time I go in or out.
A second possible solution. If you have two singe doors side by side is to have the center support taken out and a new custom width door made. I was rough quoted $3K for that and decided I could push to button and the status qua has the benefit of keeping the DW parked on her side instead of the middle.
I have seen this too. TW is usually, but not universally, several hundred pounds higher with a WDH.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 03-09-2014, 08:47 PM   #447
Experience in a little 124
First, you need a real cable to connect power. I have a weekender boat that takes shore power so the plugs are compatible. The dealership or Camping World will make sure you get the right cable. Once connected I tested everything out by running everything with a significant load at once (a/c, refrigerator, and microwave). I did not have a problem. I even added a small George Forman grill and still it did not pop the circuit breaker (either on the camper or in the house). Just make sure you have a beefy cable and a 30 amp fuse in your house before you try it.
RichardEB is offline   Reply With Quote
a128, a128s, aliner
