Old 04-14-2015, 07:47 PM   #1
A192HW Gas furnace?
My wife and I are considering buying an A192HW. If we buy the optional gas furnace, does it replace the cool cat heat pump or do you get both? Our local dealer doesn't seem to know!
Thanks,
Joe in New Hampshire
Swampweasel is offline   Reply With Quote
Old 04-14-2015, 08:11 PM   #2
RedLdr1's Avatar
We have both the furnace and the CoolCat, with the heat pump, in our T21QBHW. The heat pump won't work very well below around 40F so a furnace is a good idea IMHO. Our CoolCat is under our bed and the furnace is under the drivers side dinette seat.
Even though we have a furnace installed we use a electric space heater as it is a lot quieter. And since I'm already paying for electricity at a campground I might as well use it instead of our propane!
Wayne and Christine
2019 Sunseeker 2500TSF Pending Delivery...
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 04-14-2015, 09:52 PM   #3
What Wayne said.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 04-14-2015, 10:24 PM   #4
While sleeping in my A128:
First choice: electric heater with fan and thermostat if connected to shore power
Second choice: catalytic propane heater, quiet, requires no electric power, but has no thermostat
Third Choice: built in propane heater - very noisy, uses battery power or shore power, has thermostat
Fourth choice: cool cat heat pump - requires shore power, very noisy and vibrates, has thermostat but not effective if outside temp <40 F.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 05-02-2015, 06:54 PM   #5
A-Frame Don's Avatar
I Second This
Sounds like the way to go.
A-Frame Don is offline   Reply With Quote
Old 05-02-2015, 08:06 PM   #6
never run the coolcat for heat below the recommended temps ... it will work too hard, and likely blow the system.
d-mo
2008 Nissan Frontier 4x4
2011 Rockwood A122
D-mo is offline   Reply With Quote
furnace, gas
