04-21-2018, 01:01 PM
A212HW-Does anyone carry 2 batteries on the tow?
Does any one carry another battery with the one that came with their unit? Was thinking bout adding one since I already carry it in my car and was going to have both connected in parallel.
Would that work?
04-21-2018, 01:08 PM
Yes I have installed another 12 volt battery beside the original one on my trailer. It works well. Wired in parallel and both are deep cycle
04-22-2018, 05:55 AM
04-22-2018, 10:33 AM
Originally Posted by OYO
I'm curious, why would one use 2 6v batteries vs 2 12v? Isn't the goal when drywalling to have as much power stored as possible?
04-22-2018, 11:24 AM
I have two AGM’s.
04-22-2018, 11:26 AM
Two six volt batteries in series will yield more usable amp hours at 12v than in most cases.
I chose two G31 AGM’s in parallel. The same usable amp hours without the maintenance.
04-22-2018, 11:27 AM
There's about 1000 posts on that subject here: Electrical, Charging Systems & Solar - Forest River Forums
04-22-2018, 12:55 PM
Yes, but wont 2- 12v batteries in parallel better than 2 6v with the same setup?
04-22-2018, 02:41 PM
6v golf cart batteries generally are cheaper and provide better deep cycle chemistry for the money.
The trade off is weight. They have heavier plates and a larger form factor.
04-22-2018, 06:56 PM
I don't think weight is a problem but if I'm camping for a week, I don't think 2 6v batteries in parallel will last as long as the 12v, but I'm not an expert.
04-22-2018, 07:07 PM
2 six volt in series.
The math is simple.
04-22-2018, 07:47 PM
Two 6v golf cart batteries will last WAY longer than two 12v batteries.
Read "the 12 Volt Side of Life"
04-22-2018, 07:58 PM
Make that "two 6 volt batteries in SERIES.
You can get 12v batteries that will match the capacity of the 6v batteries but as was said, heavier plates in 6v batteries which will take a bigger beating than the 12v's in parallel.
If you are only discharging to 50% on both setups I doubt there will be any measurable difference in the short haul. Over the years the 2 6v's will hold up better.
04-22-2018, 08:06 PM
Just as confused as you
To add to bikendan's post. "The 12 Volt Side Of Life" can be found here. Forest River Forums - Downloads - 12 volt side of Life
It is downloadable for future reference.
Richard & Jill
04-25-2018, 07:51 AM
Originally Posted by Scrapper
Thanks, I need to do some reading. I'll prob stick with 12 v since I already have one for my new camper and 2 others (about 2-3 yrs old).
04-25-2018, 09:03 AM
I recently did the 2 6V batteries after reading up on everything and i'm loving it. However, you gotta buy/install them in sets of 2. For the amp hours you get and the longevity of the batteries it makes it very worth it compared to 12v batteries.
04-25-2018, 11:44 AM
194'er
It’s way more expensive to use a 12 volt deep cycle. I’m talking true deep cycle, not marine/deep cycle, those are real deep cycles. 6 volt batteries are used in golf carts so they are very common and as far as deep cycle batteries they’re cheaper.
04-25-2018, 12:39 PM
Whether you switch to 6V or not I do suggest adding a battery. I just put a second battery on, with a solar charger for each battery.
Chummy V
2014 Forester 2501TS
Ford E-450
