Old 05-11-2015, 08:38 PM   #1
A-Frame Don's Avatar
Adding LED Brake Lights
Tried to add this post to my previous one about adding a high-mount center brake light. It wasn't allowed because the original post was more than 160 days.
Today, a buddy and I added LED bar lights to my A-Frame. A high mount stop light was too hard to sort out, not wanting it to flash as a turning single. We just added two LED lights instead. They are wired as brake/park lights and still mounted high. Really BRIGHT. Attached are pics of the surgery. You really have to be extra careful when drilling. The last pic is out of focus, but you can get the idea how we fished the wires through.
ID:	76734   Click image for larger version
ID:	76735   Click image for larger version
ID:	76736   Click image for larger version
ID:	76737   Click image for larger version
2015 Rockwood A192HW
2011 KIA Sorento 6Cyl
A-Frame Don is offline   Reply With Quote
Old 05-11-2015, 09:00 PM   #2
DanM-AZ's Avatar
Thumbs up
Well that's kinda cool!
Dan
2012 Rockwood A128 (no S)
2016 Ram Power Wagon 6.4L Hemi 4x4
DanM-AZ is offline   Reply With Quote
Old 05-11-2015, 11:02 PM   #3
Nice job . Did you reseal around the trailer lights didn't look like the factory did . Good place for water to get in.
jlroadmaster is offline   Reply With Quote
Old 05-12-2015, 02:35 PM   #4
Just picked up some sealer today. Didn't have any on hand at the time and it was getting late in the day. For overnight I used tape to keep the pending rains off. The original installation was well done. I trimmed the original caulking off. Thanks for the reminder.
Old 05-13-2015, 03:26 PM   #5
Did you find that the LED lights were actually brighter that the conventional tail/brake bulb???
tyke8319 is offline   Reply With Quote
Old 05-13-2015, 03:39 PM   #6
7 Year Class A RV'er
On a side note, here's an interesting thing to keep in mind when adding or upgrading to LED brake lights. On a lot of tow vehicles and RV's, the torque converter locks automatically and unlocks when it senses a voltage draw on the brake light circuit. Since LED bulbs have such a small power draw, there's not enough there to tell the transmission you're stopping. This can result in the torque converter staying locked and wreaking havoc on your expensive transmission! There's a quick and easy solution to the issue, though. When you install the LED bulbs for the brake lights, wire a single incandescent bulb somewhere in the same circuit, most likely up under the dash just off the brake pedal switch. To keep it from looking strange, you can wrap it in electrical tape to shut off the light from the bulb. This will provide enough of a power draw to allow your transmission to sense the vehicle braking and unlock the torque converter. Good luck - hope this helps someone out down the road!
2015 Legacy SR340 360RB
Old 05-13-2015, 05:21 PM   #7
My question was in regards to the (in my case) 5th wheel brakes lights.
Old 05-13-2015, 08:11 PM   #8
Hello Conceptumator, good tips, would you care to elaborate on manufacturer's, model's? GM? Dodge? Ford?
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 05-13-2015, 08:54 PM   #9
Not sure I understand how the system works; but, I shouldn't have a problem as the original tail/brake lamps are still in operation with their incandescent bulbs. Does this mean I shouldn't change them at a later date with LED bulbs? If the TV still has incandescent bulbs, additional LEDs on the trailer shouldn't be a problem? Thanks for your input. Don
Old 05-13-2015, 09:01 PM   #10
Yes, they are much brighter. These are additional lights to the original ones on the trailer. AWESOME!
led, light, brakes
