Old 03-06-2014, 07:26 PM   #11
rawlus thanks for the tip on trailer brakes. think what a1camper and me are trying to find out is what do you consider a proper brake in is in miles or years.we both have 2014 models.did your power settings go down or up as the brake shoes seated? also under normal conditions what is a run of the mill settings you have after your break in after two or three years of use. I know they should vary with miles and other factors. how long did it take after purchase of unit to be able to reach lock using manual control ? My starcraft 19 ft hybrid would slid the wheels with higher power settings with a P2. just seems like a 14 which is max on P3is a tad high you think.
2014 A122s rockwood 2014 jeep grand Cherokee v6 290 hp 4by4
ridgeline1 is offline   Reply With Quote
Old 03-07-2014, 10:27 AM   #12
well, locking up the trailer brakes is probably not something desireable in normal operation - but i suspect that if the trailer is brand new and the brakes are brand new - they will require some time seating before you feel the full benefit of the electric braking system... a few long downhill grades where you will be applying the brakes on the tow vehicle anyway to slow down will help with bedding the brake shoes as well as cleaning off any residue or rust that may be on the trailer brakes to begin with.
as i said earlier in this post, i'll manually apply the brakes on the trailer when i am first pulling out of storage with the "oh ****" lever on my P2 controller. this is just for me to 1) test that the brakes are functioning and 2) to physically grind off any rust/debris that has accumulated on the brakes since i parked it from the last trip.
i dont remember what my numerical setting is right now on the controller - the numerical setting is not as important as how it "feels" - if it feels like the brakes are balanced between the tow vehicle and the trailer, that im not either dragging the trailer or pushing the tow vehicle, then thats the setting i go for - to me, the dial could have no numbers on it, it makes no difference, the numbers are meaningless to me as every single application is going to be different - it depends not only on how good your trailer brakes are but how good your tow vehicle brakes are.
my tow vehicle is a V8 HEMI Jeep Commander with EBC performance brake pads and EBC performance slotted and drilled disc brake rotors on all 4 corners - so the big tow vehicles braking is very efficient and consistent. so in my application, i may have the voltage for the trailer brakes set relatively low compared to someone else's vehicle.
in terms of break in for the trailer brakes - i would say 100 miles or so of varied driving, with long consistent braking down grades (which tends to be light application of your vehicle brakes over a longer time) as well as shorter stopping for red lights and stop signs (which tends to be heavier application of your vehicle brakes for a shorter time) should provide the necessary wear and tear to bed the trailer brakes to their optimum.
power setting from trip to trip fluctuated slightly and if i was driving in the mountains for an hour or two, i might even make an on the fly adjustment to get a bit more stoping power from the trailer so the tow vehicle was doing as much work on those downgrades.
i couldnt say that it consistently went in one direction or another - i just would adjust by feel, the road conditions i was currently facing and what felt the most balanced - sometimes that would be a slight adjustment up (more voltage, more brake pressure) and sometimes it would be to adjust down (less voltage, less brake pressure)
good luck
2011 A-122
rawlus is offline   Reply With Quote
Old 03-07-2014, 10:48 AM   #13
rawlus/ thanks again. sounds like you know your stuff. I am going a little stur crazy wanting to camp.Guess old retired people need something to do.hope the fl trip will take the edge off. I know there will be other questions come up after trip.aprox 2000 miles round trip. never been on gulf part of fl. we have a home in palm coast but it has been rented since 2009. its about 7 miles from old marine land. renters have never been a day late on rent/////
Old 03-07-2014, 12:00 PM   #14
yeah, enjoy yourself and have fun, dont stress the camper and towing too much, its not a complicated setup.
there are a few threads on here about mods for the a frame, id encourage you to read/look through - after youve had some camping time with the trailer youll discover your own list of things that can make it even more enjoyable.
have fun.
2011 A-122
Old 03-09-2014, 09:35 PM   #15
Jeep4Two's Avatar
I have an a126, about 2200lbs loaded, a prodigy P3 controller. I run the setting at about 7.4 and get a good balance. That setting seems to keep the trailer from 'tugging' the TV during braking while also not letting it push the TV.
I also couldn't get the trailer brakes to lock at the highest setting so just played with it to get a good balance and feel.
Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
Jeep4Two is offline   Reply With Quote
Old 03-10-2014, 08:22 AM   #16
That sums up my experience too. I get a similar stopping distance with similar peddle force towing or not towing. In contrast, the peddle force when towing is less than when the bed of the truck is loaded with heavy cargo.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
frame, a-frame
