Old 09-02-2016, 03:00 PM   #31
World Traveler Member
abdiver's Avatar
Originally Posted by JoArt View Post
I heard at a rally a couple of years ago that Les Schwab Tires stores had a lot of trailer tires in stock. Has anyone used them? I am looking for new tires for our trailer.
Also looking for a new battery too.
I went to my local shop when I had my bubble but they could only get the Load C tires not the load D which we need.
2014 A194HW
2004 Toyota 4runner V8 4WD
abdiver is offline   Reply With Quote
Old 09-02-2016, 03:45 PM   #32
Commercial Member
You need a better tire dealer.
I write a blog on RV tire application and safety and give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 09-02-2016, 05:46 PM   #33
Originally Posted by Tireman9 View Post
Sorry to hear you had a failure. Do you have pictures? It is important to know if you had a Run Low Flex failure (blowout) because of leaking air or it you suffered a Tread Separation.
This is just an internet image, but this is how it looked by the time I stopped.
And Discount Tire gave me the new one pumped up to 65 psi. So they believe it too.
The Discount Tire guy laughed when I took it in and asked if they could patch this thing up.
The Tipper is offline   Reply With Quote
Old 09-02-2016, 06:52 PM   #34
abdiver's Avatar
Nope, they check online to order for me. Question is did you get them there? I would like to know if you checked.
2014 A194HW
Old 09-03-2016, 11:13 AM   #35
Commercial Member
Without being able to do a physical examination I can't be 100% certain but because the failure does not appear to have the tell-tale sign of 360 degree mid to upper sidewall circumferential failure, I am inclined to go with Tread or belt separation. I would go with that in your complaint notice to NHTSA.
Many times this type failure can be discovered with a thorough inspection that owners can do themselves.
RV Tire Safety Blog
Old 09-06-2016, 06:03 PM   #36
Replacement Tires
I am so appreciative of this site.
I just ordered the Carlisle Radial Trail RH Trailer Tire- from Jegs 260-6H04521. They said they should be in by Saturday. Free shipping,Yeah!
So thank you for having this thread on the A-frame forum.
JoArt is offline   Reply With Quote
Old 09-06-2016, 07:54 PM   #37
That's what I'll do next time I need tires.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 09-13-2016, 10:03 AM   #38
Tire Order
Just a quick update, I ordered the tires from Jegs and had them put on local place. Even the tire installer, who specializes in trailer / tow vehicle tires, thought they were a good fit for the trailer),So we are ready to go. Thanks again for the suggestion.
Old 09-13-2016, 11:35 PM   #39
Mine came in also. Tires installed at local dealer and they refunded me the cost of the wrong tire they put on, including balance and stem....which was the cost of the two new tires I bought from Jegs. Works for me! They also put metal stems on (no charge) as they said the 8 ply (Load D) tires require the metal stem vs rubber stem.
Carla
2014 A122BH
18 Trips
47 Nights
20 Sites
6655 Miles
Carla is offline   Reply With Quote
Old 09-22-2016, 08:12 PM   #40
E trailer has a good selection of tires if you are having them shipped anyway. I've bought from them before and they are shipped quick and generally are priced right.
2016 Rockwood A212HW
2000 Ford F-250 7.3lt 2WD
2000 Ford F250 7.3lt 2WD
cantxsailor is offline   Reply With Quote
frame, replacement, tire
