Old 11-21-2015, 08:39 AM   #1
chuck9997's Avatar
Air Compressor on Aframe AC?
I bought this air compressor (below) to use with my aframe.. to top off the tires from time to time, etc. If the a122s is plugged in at home.. to a regular outlet, not a 30 amp box.. is it safe to plug this compressor into the outside outlets on the camper? I know i can turn on the lights.. run the tv, etc this way.. but would the compressor be too much?
http://www.amazon.com/PORTER-CABLE-C...Air+Compressor
2014 Rockwood Premier A-122S
2013 FORD F-150 STX, Super Cab
chuck9997 is offline   Reply With Quote
Old 11-21-2015, 08:43 AM   #2
fonzie's Avatar
It is listed at 10 amps, so it will be fine......
Fonzie
Old 11-21-2015, 08:44 AM   #3
cheriesgeek's Avatar
At 10amps, you should be fine. That is provided your extension cord is fairly heavy.
Jay
2015 A122S and 2011 Work and Play WR30
2005 F-150 SuperCrew, 5.4L, tow package, 3.73 axle
2011 F-350 SuperCrew, 6.7L, FX4, 4x4, DRW, tow package, 3.55 axle
cheriesgeek is offline   Reply With Quote
Old 11-21-2015, 08:51 AM   #4
A32Deuce's Avatar
X2!
A32Deuce is offline   Reply With Quote
Old 11-21-2015, 09:59 AM   #5
1A Camper's Avatar
There is no need to run it off the trailer. It has a 1.5 Gal tank you can fill at the house and then not mess with a power cord when filling the trailer.
At 10amps, you should be fine. That is provided your extension cord is heavy and short.
Steve and Adele
2017 RB-195
2005 Toyota 4runner 4x4
1A Camper is offline   Reply With Quote
Old 11-21-2015, 10:35 AM   #6
A32Deuce's Avatar
Or just plug into the power post at CG to fill tank, then use.
frame, a-frame
