Old 06-11-2016, 09:32 AM   #1
Air Pressure for A128S
What tire pressure do you use? Tire max rating is 55psi.
shiggins is offline   Reply With Quote
Old 06-11-2016, 07:28 PM   #2
Use the max pressure printed on the tire side wall. That is the pressure which gives them the rated weight capacity.
In my case with the "D" rated radials, it's 65 PSI.
If you have 55 PSI tires, they may be load range "C." "D" tires are required to cover the full GVWR of a camper. I'd check the sidewalls again for a weight rating and compare it to the real weight of the camper to make sure the tires are not overweight.
The only time I've had a blow out was when a shop put "C" rated tires on a camper. It is amazing how ignorant a tire shop can be about camper tires.
Tom
2012 Rockwood A122S
2008 Toyota Tundra Double Cab 4X4
Former owner of a 2002 Coleman Niagara GTE
Pooneil is offline   Reply With Quote
Old 06-12-2016, 09:32 AM   #3
Are you sure it says 55? I have not seen a 55 before. Mine are also 65 psi. As stated go with the max pressure as stated on the tire.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 06-12-2016, 09:37 AM   #4
Dsfast's Avatar
On the drivers side of your trailer you will see tire psi as the manufacturers specs that's the pressure you should use
Dsfast is offline   Reply With Quote
Old 06-14-2016, 07:52 PM   #5
My Mistake
yes its 65 max pressure which is also called for on the drivers side.
If I'm not carrying a max load should I still keep the tires at 65psi?
Old 06-14-2016, 08:38 PM   #6
Yes, run the max pressure.
That is the basic safety rule.
mickrock is offline   Reply With Quote
Old 06-16-2016, 01:07 PM   #7
Do you know the capacity of the tires when not at max load? Some manufacturers publish this info and some do not. I've never seen it for the Karrier tires on an A Frame. If you don't know, then run at max pressure.
Tom
2012 Rockwood A122S
a128, a128s, pressure
