Old 10-25-2012, 06:48 PM   #1
Anode Rod
I have some questions regarding the anode rod. Any help is much appreciated.
1. Can anyone else verify the size of the anode as 1 1/16? This size is available in a set of 8 or 10 sockets for $70. 1" would be waaaaaay better on the ol' wallet. The manual does not state the size.
2. The manual states that the rod should be changed every year...does this seem to be what everyone is getting out of theirs? Is thread sealer a must do?
Thanks Again,
LM
2012 Flagstaff T-12DD
2004 Chevy Suburban
2000 GMC Sierra Z-71
loganmartin is offline   Reply With Quote
Old 10-25-2012, 06:56 PM   #2
Campin' in Canada
ParkManCan's Avatar
Most anode rods do use a 1 1/16" socket, got ours at Lowes for $6 (1/2" drive) Depending on the water the rod breaks down slowly, ours barely wore down at all after the first season, I can see it lasting a few years.
2011 Wildwood 37bhss2q
Permanently Parked
Just me & the DW
ParkManCan is offline   Reply With Quote
Old 10-25-2012, 07:05 PM   #3
Old car's Avatar
1-1/16" on mine for a 1/2" drive socket. Don't remember the cost but I bought an individual socket at one of the big box hardware chains. Just pulled my anode rod the other night and after two full seasons ours shows very little erosion. We will definitely get next season out of it and at this pace; many more.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 10-25-2012, 07:25 PM   #4
Timex's Avatar
Got my socket at Lowes also. I use a breaker bar with a socket on the end as a lug wrench. Just switch the sockets for the anode rod. Pic #3 is after 18 months of ownership.
ID:	21037   Click image for larger version
ID:	21038   Click image for larger version
Timex is offline   Reply With Quote
Old 10-25-2012, 07:49 PM   #5
Sounds like Lowes is the the place then....6 bucks is right up my alley. Home Depot just had it in a larger set with a bunch of sockets I don't need. Any thoughts on thread sealer?
Thanks,
LM
2004 Chevy Suburban
Old 10-25-2012, 07:53 PM   #6
Individual socket, got mine at northern tool for cheap. Use a breaker bar with swivel in the end, 1\2" drive also at northern tool.
For threads use Teflon tape, you do not need to torque it down too hard, just enough that it doesn't leak. The Teflon will help keep the threads from corroding and locking the whole thing together so it's impossible to budge.
Anode should last a good long time depending in water quality, even longer if you drain the water heater between trips.
2011 A-122
rawlus is offline   Reply With Quote
Old 10-25-2012, 07:54 PM   #7
Thanks,
LM
Teflon tape only, about 3 or 4 rounds and only tighten enough to keep it from leaking. Recommend putting it in finger tight and turn the city water on and slowly tighten until it quits leaking.
Old 10-25-2012, 08:03 PM   #8
Those are good tips fellas....I do appreciate it. The outside of my current anode was rusty when I got the camper this spring so it could be gone by now...we'll see in the a.m.
LM
2004 Chevy Suburban
Old 10-25-2012, 08:13 PM   #9
I would be very surprised if it lasted only one season. It can take years to corrode down to the core wire.
2011 A-122
Old 10-25-2012, 08:13 PM   #10
VinceU's Avatar
Seeing some anodes near perfect after 12-18 months = something is wrong! Its really called sacrificial anode and is designed to give it self up to surrounding metal.
Does anyone ever use a resistance meter (multimeter) to check center of anode nut to frame? The annode will not work if not grounded. Too much tape or dope could insulate the rod from the frame
anode
